Elf Ears, Custom-made in Silicone Rubber
253,386
491
41
Published
Introduction: Elf Ears, Custom-made in Silicone Rubber
  While costume shops have been selling foam latex pointed ears for some time, their generic one-size-fits-all shape means a standard and relatively bulky set of points which can never completely blend with a human’s natural earlobes.   The extra-soft and porous nature of foam latex also means the ears are limited to a few applications before giving in to the stresses of repeated use.
  In this Instructable you will learn how to make your own custom-fit set of pointed elf ear appliances from two-part silicone rubber, a non-porous material which can be glued, applied, removed, cleaned, and reused many, many times.  I have been using the same pair for a few years now, so if you are attentive and careful, your ears could last indefinitely.
Edit:  The silicone rubber I am using here is Douglas & Sturgess brand SR-1610.  Smooth-on makes rubbers with comparable properties for their Dragon Skin line.  Use the softest mixture available, with the least amount of color.  One of the advantages of silicone is it's ability to scatter light and create a realistic flesh-like glow and be transparent enough to blend into real flesh.
I make my ears at TechShop.
Also works for: faeries, fairies, pixies, pillywiggins, goblins, hobgoblins, demons, leprechauns, gnomes, hobbits, nymphs, naiads, sylphs, satyrs, imps, demons, orks, vulcans, romulans, werewolves, na’vi
Step 1: Aquire:
Most of these materials are available through smooth-on.com
  -Alginate/Dermagel
  -Plaster (I recommend Ultracal or another thin and extra-hard-setting mixture)
  -Silicone rubber (soft and translucent)
  -Petroleum Jelly
  -Ear plugs
  -Clay (non-drying and sulfur-free)
  -Silicone pigment or acrylic paint to match your human’s skin tone
  -Spirit gum or medical adhesive
  -A silicone-friendly release agent (here I am using Ease Release 200)
  -Foundation makeup
  -Mixing cups and stir sticks
  -2 large clamps
  -Water
Step 2: Prepping Your Human
Prep your human’s ear with the petroleum jelly and ear plugs.  Be conservative with the greasy stuff, alginate will generally not stick much by itself and residual petroleum will interfere with the silicone curing process.
  Cut out a hole in the bottom of a cup or bowl just big enough to fit one ear through.  This will keep the alginate from running and will produce a stable and easily handled housing for the negative mold of your human’s ear.  Sit your human comfortably with their head resting on its side and have them help hold the mold housing in place.
Step 3: On the Mixing of Alginate
This part requires you to work fast because the alginate will set quickly if properly mixed.  Add the alginate powder to half a cup of water.  Mix it in and keep adding powder until it is just thick enough that it will hold some of its shape.  Begin to apply to the human’s ear by working it into the interior curves.  You do not want air bubbles forming there.
  Next, fill-in around the outside of the ear.  The alginate will run to fill-in much of the area, but you need to build a thick layer around the top and outer edge of the lobe.  Mix more alginate if necessary to create a stable mold which can hold its own shape without an ear inside.
  In 15-20 minutes alginate will set to a semi-solid gelatinous consistency which will hold fine detail but will still be very wet to the touch.
Step 4: Release the Mold!
Have your human gently pull their ear from the solid alginate.  Check for air bubbles.  If your mold is good, begin to mix the plaster right away since the alginate will shrink as it dries-out.
  Mixing plaster is a similar process to mixing alginate, except that a more thorough mixing is required for optimum results.  It is also harder to add water to a plaster mixture which is too dry.  Start with the water and gradually add plaster.  Ultracal generally works with a mixture of five parts plaster to two parts water.  The final mixture will be thin and watery to capture extremely fine details, but too much water will produce a weak casting.
  Pour the plaster into the negative mold.  Be sure to shake or tap out air bubbles, as they will ruin your casting.  The alginate is a one-time mold and you will have to destroy it to remove your plaster positive ear.  Your plaster mold should overfloweth.  Although the Ultracal will set in less than an hour, it is best to give it several hours to reach full hardness, especially with such thin shapes in the very wet negative alginate mold.
Step 5: Release the Mold (part II)
Pull the alginate mold from off the replicated plaster ear.  Only now will you be able to tell if both of your pours went right.
Step 6: Building the Elven Points
  Using a non-sulfur, non-drying clay, (sulfurous clay like Roma Plastilina will affect the curing of the final silicone rubber appliance) sculpt the two points from where they diverge from the natural shape of the ear.  Because the silicone you will be using is translucent, you will not need to create a super-thin flange for blending the edge to the human’s real ear (that would also complicate the gluing process).  Create a sharp angle but wth a well-defined edge.  Silicone is much heavier than foam latex, so be frugal with the clay and keep the part thin.  Sculpt the lower flange contacting the back of the earlobe thicker.  This will give a strong bond to the human’s ear and provide ballast to the perkiness of the elven points.
Step 7: Making the Production Mold
The complex shape of the ear makes a single-part solid mold impractical.  I have opted to pour a cast for the back part of the ear and wait for it to set, then add a release agent and pour a mold for the front half.  Your seam will be along the outer edge of the lobe, and may result in a thin flashing on the final appliance.  This is usually thin enough that it can be trimmed without leaving a visible artifact.
  Here I am adding extra clay to cover almost every bit of the plaster that is not covered by the point extension.  This will allow for an easy release of the plaster halves.  I am using Ease Release 200 and some thin sheets of aluminum foil to better demarcate the two plaster halves (a plaster mold from a plaster mold can be a tricky separation.)
Step 8: Pouring the Silicone
Once the plaster mold is completely dry, pry the two halves apart.  Remove the clay that makes up the point of the ear, and pour in the silicone rubber.  Although distributors will sell pigments in a variety of colors which can be mixed to produce skin tone, I have found acrylic paint to work just as well for flat, natural colors.  A little bit will go a long way, and you want to keep some translucently to the rubber, so start with a drop and add more if you need to.  Mix the paint into the Part A and then add Part B.  Extra additives are available to increase or decrease the viscosity of the rubber, though I have opted not to use them.
  Silicone rubber resists sticking to most non-silicone surfaces, even porous ones like plaster.  I use a light spray of Ease Release 200.  Too much will cause a loss in definition and will give the final appliance a slick, waxy finish, which will look more like a special effect than a real earlobe.
  There is a similar issue here as with pouring the mold over the human’s natural ear.  There are many places for air bubbles to hide and not an easy way to ensure an even pour.  You must first coat every surface, the inside walls of the outer mold and the outside of the positive ear mold.  It’s okay for some to overfow, there is actually no way to avoid that.  You can trim it afterwards.
  Put the back half of the outside mold into its place.
  Immediately after applying a thick coat, place the front half of the outside mold on top.  Clamp the parts together and turn upside down.  If there are any air bubbles inside, this will ensure that they float to the back of the appliance where they will be less visible.
Step 9: Release Your Elven Features From Their Prison of Stone
  Remove the cured silicone parts and trim the flashing.  A well-constructed appliance will hold itself in place on a human's earlobe, without the application of glue.  An adhesive is necessary to hold down the edges and keep the ears on during a voyage to Valinor or while battling the armies of Mordor.  I use spirit gum, or the slightly higher-end medical adhesive.  Further blending and color-matching can be accomplished with a little foundation make-up.
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    • Casting Contest
      Casting Contest
    41 Comments
    This is amazing! I really want to make them.
    This is fantastic, I've never done casting before and have been looking for an explanation on how to achieve more complex sculpted ear points. The only part I find confusing is in step 8. Do you remove the entire original ear cast in the process of removing the wet clay point? If so, how do you get it back in position correctly? Or is it adhered to the bottom part of the mold? In which case why did you cover it with we clay back in step 7 and not just the mold release spray you used elsewhere?
    Wow, great project!
    I was wondering... where did you get your silicone rubber?
    I am looking at making full Elf ears, as opposed to cuffs for my senior project, do you have any recommendations or changes in steps that you would suggest in order to accomplish this?
    Wonderful tutorial! I've made two-part molds before and I was wondering if you could clarify a part of your molding/casting process; did you make the ultracal ear cast part of the mold, or did you keep it separate and place it in between the molds when you casted the silicone?
    so in the list for what will work for each race... i don't see the name Elf in the list o-o
    "Elf" is in the title, the list is "Also works for:"
    What about using polyester resin instead of plaster? Would that be less likely to crack when removed from the mold?
    I want to try to make this but I've got a question about how long should the silicone sit in the mold? I just need an estimate so I won't be messing with it while its curing.
    Whatever silicone you buy should give you a cure time on the packaging, the ones I've used have all been around eight hours. There are some that only require forty minutes and some that set in ten minutes.
    Thanks! You helped me figure out exactly what I did wrong...I did not add enough of "part b" to the RTV. Just made a pair and they look Lovely! Thanks!
    So I've read through all the steps and read through all the comments, including the one from rdisley where you say that you use the ear cast inside the final silicone cast, but I'm still a bit confused. How do you get the original ear cast out of the second mold (the two part one), I know you said that you cleaned the clay off the point, was that what the other clay you added in step 7 was for? So the mold wouldn't stick to the ear cast? Should that also be removed or left on? Can you reuse the original ear cast or is it a one time deal? I kind wish you had included a pic of the empty mold after cleaning out the clay and prior to pouring in the silicone, otherwise this is such an EXCELLENT tutorial!! I'm SO excited to try it out! Thank you so much!!
    I'm sorry. I know you've been very nice to include what you used but I can't understand the terminology and there are so many silicone rubbers and brands to choose from with the same names I can't tell them apart. Could you maybe include en exact link?
    http://www.smooth-on.com/Silicone-Rubber-an/c2_1115/index.html
    So when you say, non drying sulfur free clay, what is that exactly? Cernit? Polymer? Play.doh?
    I wouldn't recommend Play doh, as it does have a tendency to dry. The ideal clay would be oil-based, like Plasticine. I often use Roma Plastalina/Plastaline, though the sulfur content can react with silicone. A urethane coating over the clay will prevent this.
    Incredible work, really. There are lots of quality, creative instructibles around, but this has gotta be in the all-time top ten. Your work here certainly makes a lot of very well paid Hollywood-types look like amateurs. Very well done.
    I do have one question: elf/hobbit/Tolkien-realm ears are always pointed and somewhat flared out, which you illustrated perfectly here, but if I were to use this process for a more alien-type or blunted tip ear, do you have any ideas on how to shape the prosthetic so that it curves more inward, as if to follow the shape of the back of the skull, remaining more flush with the hairline? I don't think it will be difficult to mold in clay, but I'm concerned that ill have problems with glue adherence since the prosthetic will be directing away from the natural structure of the ear, rather than extending it like elf ears.
    Thanks in advance for any thoughts/advice. My question seemed simple enough in my head, but it suddenly got complicated during the translation to text. I hope it makes sense. :-)
    These turned out lovely, but I don't exactly understand how you keep the prosthetic hollow so it will fit over the ear...
    In steps 5 and 6 you can see the replica ear, this is used inside the mold in step 8 to creat an ear-shaped interior.
