Step 2Hooking it up
The USB port outputs 5.05V normally, so that is also an option.
I originally had a broken fiber optic light that took 3 AA batteries. One AA or AAA battery is 1.5 volts. The fiber optic light had the batteries connected in series, so the actual output was 3x1.5 = 4.5volts. I originally used the fiber optic lights power source cut out and put in the Tupperware container with the GPS unit. The only difference is that there was no voltage regulator. I just hooked the grounds together and directly soldered the wires.
Add Comment
