Embedding Hardware Into 3d Print
15,392
192
6
Published
Introduction: Embedding Hardware Into 3d Print
I have been using my solidoodle 4 on little projects at home for about half a year now. And occasionally I need to mount my printed parts to something. Superglue takes to both ABS and PLA pretty well, but nothing beats the strength and durability of metal nuts and bolts.
This is my little trick of hiding the unsightly hardware in your printed part.
Step 1: Measure Hex Nut
First you must measure the hex nut you plan on using. If you do not have calipers a quick google search will give you a chart and you can find the dimensions you need.
Step 2: Add Cavity in Your 3D CAD Design
Here is an example of clearance for a 5/16-18 hex nut. I like to space my hex nuts about .100" from the surface. I give the hex nuts about .015" clearance per side for a light press fit (but that may differ with your printer).
Lastly, make sure to give plenty of clearance for the bolt to screw threw the hex nut.
Step 3: Slicing and Printing
After my slicing program is complete I look through the layers and determine the last layer before the cavity is closed up. In my example layer 35 is open and 36 is covered up.
From here I can either manually pause the print during layer 35 or I can insert a G-code text to pause and move the printer head.
Once paused I insert the hex nut and resume the print.
Step 4: Complete
Now you have a 3D printed part that can accept a threaded bolt
Step 5: Strength Analysis
Thanks for the comment stechi! I decided to put a little thought into the strength of hold this technique can yield.
First of all, I think there are at least (2) types of part mating we need to consider for strength analysis.
-OPEN MATE:
In this case the first thing to consider is how much space (Distance D) the printed part is spanning. I have not done any real tests, but I would guess at around 3.0" and larger tightening the bolt would warp the outer wall of the printed part and possibly break through. I think adjusting the print settings for wall thickness (T) and the infill % would help aid in the strength of this mate.
-FLUSH MATE:
In this case the thickness (T) is sandwiched between the hex nut and the mating part. Minimal thickness is acceptable (too thin and you may see the hex nut's shadow). I have found the weakness of this mate (this would apply to the Open Mate) is torquing the bolt through the "interior perimeter thickness". Adjusting infill % helps aid in strength, but I have found adjusting the number of interior perimeter layers is most effective.
I do not have any torque wrenches to do a real test and I would be interested to see some results, but I can say they hex nuts hold pretty well with basic print settings. I would guess I can tighten the bolts around the same torque it takes to open a beer bottle before I hear cracking plastic.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    My printer (using Cura) will automatically print a thin support in the void where I want to put the nut. How can I selectively not print in the void where the nut will go?
    6 Comments
    In terms of strength. I simply put a solid tube around the bolt. 1/16th" (1.6mm) thickness is what my printer prints before putting an air gap. This tube will not compress much. If one tube is not strong enough. Add more concentric tubes with an air gap between. Or an asterix (spoke like) pattern of internal walls.
    I'd like to see what your securing. But a 5/16 screw holding plastic components together? C'mon now. Even a 1/4 screw would be overkill!
    Wouldn't a 10-24 or 8-32 be sufficient!
    You might also consider parking a fully enclosed hole but then pushing in a thermoplastic insert. You print as is witha suitable hole, then place the insert and push in with a soldering iron. If you did not come out the other side and your hole closes up to cover the lip of the insert you should have the insert tightly in. In ABS I have found post print installation of these very effective so I wonder how well it will work mid-print.
    This looks a good, simple way to make fixings! I think there is a bit of a research project here on how deep to embed the nut - the nut is going to be very much stronger than the 0.100" thickness of material holding it in. Also there might be some torque issues on tightening it, when will it break out, the wall thickness might be more critical...? I'll think about getting some experiments done on this! Thanks for getting me thinking!
    Hey thanks for the comment. I hadn't really thought about the strength of hold. I added another step in the instructable with some of my ideas. Let me know what you think.
    Brilliant idea!
