Emboss Velvet with Rubber Stamps and a Household Iron by Inklings and Imprints
Featured
Embossed velvet is striking and beautiful. Images are sunk into the pile of the velvet so that you get a textural as well as visual effect. The images often also take on an iridescent quality.
Embossing velvet is easier than one might think...
The embossed images are created using heat, producing sunken and iridescent images that can appear shadowy or very reflective depending upon the angle and the folds and fall of the fabric - that is why it can be so tricky to photograph them. Parts of an image may appear "shadowed" while other parts shimmer.
The images are resilient. I have embossed acetate/rayon velvet scarves that I have worn all winter long for several years. They get wet from snow, sleet and rain; get scrunched up, rolled up, sat upon, etc., and the images are still there, even if they are not as crisp as they used to be. I am not recommending this type of treatment, but mention it to give an idea of how the images can last.
It appears that impressing images into velvet using heat may have been around since at least the 16th century. Metal was heated and pressed to the velvet. In the 1990's, Mary O'Neil of Hot Potatoes stamps popularized the use of rubber stamps for the process. For use at home, rubber stamps are obviously easier and safer to use than hot metal.
Care of the resulting velvet: Dry clean only. As with most velvets, the fabric may develop shiny spots if spot-treated or excessively rubbed. Washing/soaking the velvet could result in an uneven look to the velvet (shiny and dark areas) and could loosen the pressed fibers of the images, causing them to appear ghostly and blurry.
Uses for Embossed Velvet: Embossed velvet can be used for clothing and accessories (jackets, bags/purses, scarves, shawls, robes, shirts, dresses, skirts, hats, earmuffs, mittens, cowls, slippers, etc.), as well as items for the home and gifts (throws, curtains, pillows, sachets, runners, wall hangings, upholstery, boxes, ornaments, jewelry and gift bags, journal covers, etc.).
More info and images on my site: inklingsandimprints.net. Images are also up on Flickr. My partner and I designed all of the stamps shown in this tutorial. They are available on our website.
Text and images are copyrighted by Inklings and Imprints. All rights reserved.
Step 1: What you will need
- Iron (with Teflon iron shoe/cover, if possible). A clean, smooth and relatively steam-hole free surface area is best.
- Velvet: acetate/rayon blend is best. Rayon, silk/rayon blend or silk can work. (I have more info on what types of velvet work best and what safety issues there may be with certain velvets.)
- Water misting/spritzing bottle
- Stamp backed with mounting cushion at least 1/8 inch thick, no mounting block needed. Notes on stamps. The stamp used in this tutorial is our Celtic Knotwork Triangle Stamp. We have it available trimmed and mounted on cling cushion, as shown - full or partial sets - or as uncut and unmounted full or partial sets.
- Iron-safe surface
Always do some test swatches for each type of velvet you use so you can vary spritzing, iron temperature, etc.
1-40 of 43Next »
karossii says: May 12, 2012. 6:54 PM
I'm looking to do this with a jacket I am having made... how large of a stamp can be used effectively, and would it be okay to have it made of wood instead of a rubber stamp?
gallimaufry says: May 3, 2010. 6:34 AM
Wow - I hadn't heard of this before - have to try it soon.  Thanks for the clear instructions.
marjorieallea says: Dec 3, 2009. 10:15 AM
 Those are beautiful...
lynks says: Feb 20, 2009. 1:17 PM
Thanks, this is great for people who do reenacting or ren faires, as velvet was treated this way in the 16-17 centuries.
Inklings and Imprints (author) says: Mar 7, 2009. 2:33 PM
Yes - although the velvets would have had a different makeup than the ones that work best for embossing with rubber stamps. I think it must have taken much higher temps to emboss the velvets available back then. Enjoy!
cutekitten says: Feb 13, 2009. 8:14 PM
wow thats neat thanks for sharing
kathynv says: Dec 6, 2008. 12:41 AM
That is so very pretty, and looks like one of those crafts where the result is a lot more than the effort expended, if that makes any sense at all. The key seems to be picking the right stamps for the garment/finished product. I think I know what decorative element I am adding to my holiday jumper. Thanks for sharing this - it's nicer than adding a trim to a garment, and adds even more decoration.
Inklings and Imprints (author) says: Dec 6, 2008. 12:11 PM
Yup, it is very rewarding - a great "payoff" for the effort? Are you making the jumper? Be sure that you aren't trying to emboss anywhere where there is a seam - unless you don't mind if the images aren't uniformly deep/clear. That sounds lovely. Maybe post pics here in the comments if you take any. ? Take care
crafty_carrie says: Aug 22, 2008. 11:02 AM
Thanks for a fabulous tutorial. Can you make the imprints with other materials than rubber stamps? (Wood, metal, potato stamps, etc.?)
Inklings and Imprints (author) says: Dec 5, 2008. 10:10 PM
Ha - I just noticed that you asked about potatoes. Um... I don't think most food products would work well for heat embossing... unless they were really old and krusty. Maybe beef jerky would work, or nuts...
Cheers!
Inklings and Imprints (author) says: Aug 22, 2008. 11:29 AM
Yup - anything that has a raised texture and won't melt under heat. Lace, wire mesh, metal batiking stamps, woodblocks, etc.. If you are using something that has a smoother and harder surface, you may have to practice a bit so that the velvet doesn't slide against the surface, creating double or ghostly edges.
giddiups says: Nov 28, 2008. 9:19 AM
I have been looking for rayon velvet ribbon wide enough to use my stamps, but have been unable to find any at least 2" wide. Any help will be appreciated. I would like to make some things for Christmas and time is getting kinda short. thanks giddi
Inklings and Imprints (author) says: Dec 1, 2008. 2:03 PM
Hi - I know that I have seen embossable ribbon for sale online in the past, but I just tried a few searches and am not coming up with anything. Sorry I can't help... Maybe ask at your local craft store - they may have a supplier who carries that kind of ribbon and could do a special order.
giddiups says: Nov 28, 2008. 9:20 AM
p.s. I would like to have the "wired" ribbon as most will be used for book marks thanx
drascombe says: Nov 23, 2008. 5:54 PM
Well, I did emboss red velvet with Xmas stamps to make scarves as Xmas gifts. My kids helped with the embossing and sewing ('tho I did most of it) I wanted to report back that I did try embossing on velour. I took my daughter's old velour sweatpants, and embossed along the bottom hem. I was fearful of burning the fabric, but I set it to the same heat setting as for velvet. It sort of worked - the pattern showed up, but it didn't burn away the nap. So the pattern only lasted until the next washing, and then it sort of brushed out. So, I guess if you want temporary patterns, you could try velour. Actually, that may be a bonus for my daughter - we can change the stamp patterns often!
Inklings and Imprints (author) says: Nov 24, 2008. 3:38 AM
Ha - kind of like a temporary tattoo... Thanks for reporting back on this. Feel free to post some pictures of your scarves here if you would like - there should be an option to add images to comments. I'm glad that the velour you used wasn't dangerous to iron. Just as a note to anyone else who might want to try it: please do proceed carefully as not all velour may respond the same way to heat. Take care
drascombe says: Nov 9, 2008. 5:37 AM
Can embossing be done on other flocked fabrics? What about velour? My daughter lovers her velour stretchy pants, and this would be a great way to personalize them.
Inklings and Imprints (author) says: Nov 9, 2008. 11:57 AM
Hmm - I'm finding results for embossed velour for sale online, but I'm not sure how that process is done. I don't know if what is offered is heat-embossed or if the nap is cut to produce the effect. If I hadn't seen those search results, I would have said that velour can't be embossed.
Since I'm not sure, I will have to say that it "may be" possible that the steps I outline could emboss velour, but I would have concerns about safety and effectiveness. (Just because something can be done in a factory, does not mean it should be tried at home!)
You would want to be positive about the fiber content of the fabric, as some fibers can melt or catch fire if concentrated heat is applied. See this page on my site for details: http://inklingsandimprints.net/pages/velvetcontent.phphttp://inklingsandimprints.net/pages/velvetcontent.php
If you are positive that you have a velour that doesn't contain any materials that can't withstand heat, I would still do a number of test swatches, starting with the iron on a bit lower than I normally recommend, just in case. Be sure to have good ventilation and move any flammables away from the work area.
Do let me know your results - I'd be interested either way!
Cheers
Inklings and Imprints (author) says: Nov 9, 2008. 11:58 AM
oops - not sure why the link appeared twice. seems to work, anyway.
filigreeliv says: Nov 8, 2008. 4:55 PM
Very clear instructions and helpful tips both here and on website. Thanks.
Inklings and Imprints (author) says: Nov 9, 2008. 11:01 AM
Glad to hear it - thanks for commenting!
bugcam says: Oct 9, 2008. 7:53 PM
has anyone tried using a heavy lace as a stamp for this craft...just wondering, would love to see that effect!
Inklings and Imprints (author) says: Oct 10, 2008. 2:07 PM
You know - I've not actually tried it. I've read it mentioned a number of times online, but have yet to actually see either images or tutorials reporting results. I just did a quick search online and didn't find anything, either - many sites mentioning lace as an option, but with no other info. Hmmm - maybe I've just been parroting the idea that it can be done, along with many others, but no one can actually report any success?
Because lace is only so thick, I would think that it would be very hard (or impossible) to get a crisp, consistent or complete transfer of the lace pattern. I think you could get some very lovely patterns, though, that would sort of fade in and out a bit.
Again, do be aware of the content of the lace, though. Anything with nylon or some other petroleum-based material might lead to some nasty sticky, smokey, chokey surprises!
If you do try it, let me know - I'd be very interested in the results.
Cheers!
bugcam says: Oct 10, 2008. 3:21 PM
will let you know,lol.
bugcam says: Oct 9, 2008. 7:51 PM
Well presented info, Thanks sooo much. Beautiful work, cant wait to try it. Oh, can be drycleaned...great! hmmm, giftbags, scarves, wizard capes, lol... I have some lino blocks that I made a while back, will try them out. Favorited this instructable!!
Inklings and Imprints (author) says: Oct 10, 2008. 1:58 PM
Glad you like it! It is a great craft.
k24tea says: Sep 19, 2008. 10:33 AM
I love this!!! I'm going to emboss some velvet ribbon and use it to make a few big covered buttons for a fancy jacket. I'll post pix if they come out nice and my camera still works. Thanks for a great Instructable!
Inklings and Imprints (author) says: Sep 19, 2008. 6:53 PM
Oh - that sounds lovely, I would love to see that - I do hope to see pics! Cheers and thanks
GreetaSue says: Sep 6, 2008. 1:30 PM
Yummy! I can't wait to start thinking up projects to do this on. Thanks!
Inklings and Imprints (author) says: Sep 6, 2008. 6:40 PM
I hope to post a tutorial on making balsam sachets in a bit. A lot going on, but it is on the list! Eventually I will also post on making fleece-lined scarves, maybe mittens and a hat... and probably a journal cover. Cheers
noahh says: Aug 12, 2008. 10:33 PM
this looks great!
Inklings and Imprints (author) says: Sep 3, 2008. 8:29 AM
Overdue: Thanks! I just realized that I haven't been posting replies directly to comments. Oops.
aliceownsj00 says: Aug 13, 2008. 1:18 AM
omg I have always wondered how to do that at home o.o very cool and very simple! great tutorial, nice pictures too!
Inklings and Imprints (author) says: Sep 3, 2008. 8:28 AM
Gracias!
zombiehottie0900 says: Sep 3, 2008. 7:13 AM
beautiful!
Thanks - it is satisfying. Cheers
Grey_Wolfe says: Aug 13, 2008. 11:52 AM
I love this project. Where did you happen to get your stamps? The triangle one is lovely.
Inklings and Imprints (author) says: Aug 13, 2008. 1:05 PM
We actually design our own stamps. We carry sets on our website - I have a link in the intro. Take care
Grey_Wolfe says: Aug 19, 2008. 1:15 AM
I missed that. Thanks.
Flumpkins says: Aug 16, 2008. 7:57 PM
Whaa?!?
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
