Embroidered fabric cuff bracelet by mynameiswool
Featured
Step 6: Pin together and stitch
Take your embroidered piece and place it face down (right sides together) over the un-embroidered piece. Using small straight pins (or even safety pins if that's all you have), pin the pieces together.
You will have the two little elastic tails sticking out on one short side; the rest of the loop should be sandwiched between the two pieces. If you have never sewn before this might be odd to you, but just trust me, this is correct. :)
Now, stitch around three of the sides with a 1/4" seam allowance, leaving the short side without the elastic un-stitched. I used a serger with a 4-thread overlock, which has two rows of stitches going around the edge and is nice and strong.
If you are using a conventional sewing machine or sewing by hand, you should add another row of stitches along the short edge with the elastic to help secure it in place.
If you are hand-stitching, I recommend a backstitch or something similar for the best results; it is sturdier than a running stitch.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
