Step 3Threading the needle and all about floss.
Also: keep in mind that you do not double the floss as you sometimes do with thread. You're simply going to pull the thread through the eye and let a few inches hang loose. You'll knot the other end as usual. (And make sure to cut off the loose stuff after the knot - it'll make your work neater! Never leave more than 1/2 inch behind the knot, or it'll get tangled while you stitch.)
Most floss is multi strand. The most common is six strands. You can divide the floss for more detailed work. The best way to do this it to use your fingernails to separate the strands and then pull is apart slowly. :)
comment
Add Comment
Add Comment
