Emergency As Well As Portable High Bright Light
550
4
Posted in TechnologyElectronics
Introduction: Emergency As Well As Portable High Bright Light
Hi everyone today i will show you how to make high bright emergency as well as portable light.
Step 1: Introduction
the main purpose for this project is to make a source of light which is very useful in the power cut time in villages as well as it is also helpful in picnics,trecking,jungle ride or any emergency time where electricity is not there and this will be also helpful in daily life like in garage or outhouse etc where portable light is needed.
[in this instructable the plastic container is not showed but it is necessary to keep it in the plastic container in order to protect parts battery and led from dust moisture,etc]
Step 2: Things You Will Needed to Build This Are:-
1.one plastic container or casing
2.high bright led of 5Watt each [total 3 needed]
3.12V 1A power source[adapter]
4.one 9 volt battery [rechargable or disposable any one]
5.one battery holder for 9v battery
6.one large heat sink[two ic heat sink will be appropriate for three high bright 5Watt led]
7.connecting wires
8.three pin two way switch [one can get easily from handmixture,etc]
Step 3: The Circuit and Connection Arrangement:-
as shown in the picture connect the positive terminal of the adapter source to the switch's first pin and negative pin to the led light
then after connect positive wire of the led light to the middle pin of the switch and connect the positive wire of the battery to the last pin of the switch and negative wire of battery to the negative wire of led.and now th circuit arrangement for you emergency as well as portable light is ready at last place all this in the plastic container and keep led out and close the container now the best light source for the emergency is ready for use.
Step 4: Testing It
as per the instructable created by me this arrangement will work and it will be also useful in emergency situation like power cuts,etc
thanks for watching this project and hope you enjoyed my project.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
