Emergency Bathroom Lock
Introduction: Emergency Bathroom Lock
I've just replaced my doors with brand new nice oak ones. I want to take my time to pick a nice lock, and fit it well. I also had some friends staying, who wanted a bathroom lock.
The conundrum: How do I lock the door without marking it in any way?
The solution: String and tube!
Step 1: How It Works
If the handle can't turn, the latch can't open, and neither can the door.
The first thing I tried, was cutting a length of wood the right length to jam under the handle on the inside. It worked fine, but having a length of wood in the bathroom was confusing to people.
I happened to have some 1" perspex tubing from the RGB fishtank project it fitted nicely oven the handle. Now I just had to tie string onto it, stop it sliding up and down with duct tape, take the string over the door, wrap it around the base of the handle on the other side, then back over the door, tie it onto the tube keeping the string nice and tight, and secure in place with duct tape.
Step 2: The Results
It works great! And it only took a minute or two to make!
It's a bit tight to get onto the handle. But it needs to be, to stop it from moving.
In an emergency you can just cut the string to get in! No damage to the door.
The plastic tube taps against the door as you open and close it. The sharp edges on the tube can slightly mark the varnish. You have to look really closely to see. I'd recommend putting a radius on all the sharp edges to stop this from happening to you.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    You install new doors and forget the lock? What the heck? Place a boulder in the toilet and roll it to block the door!
    If you look closely at the door frame in the interior photo, you might make out the remains of where the bolt used to be. The old door furniture was brass and surface mounted. When I replaced the doors, I replaced the handles with chrome ones. I wanted a nice chrome lock that could be opened from the outside in case of emergency, but the shop didn't sell one. I've got one now. I'm just taking my time to do the job well.
