3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Emergency Battery in the Wilderness
Step 3Testing the Battery
Testing the Battery
Now when you take a light from a bycicle and connect it to the battery, it lights up! I don't have access to such a light at the moment, so I just tested it with my multimeter. In the picture below, i had the meter set on a range of 10 Volt, so as you can see it reaches 1,9 Volt, that's almost 1,5, which is the common battery voltage and used in almost all flashlights. I think you could use this battery in a flashlight aswell, but if you just remove one coin, aluminum, and paper towel(together one battery), the voltage will decrease a bit, because the batteries are in a series. So by just adjusting the length a bit, you can get the desired voltage! If you double the length, the voltage doubles aswell.
What you see is an electric current based on a redox reaction with copper and aluminum in a sour environment. If you're not familiar with redox reactions you can learn more about them here.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
167
Author:merijnvw(my company)
I'm Merijn van Wouden and I live in The Netherlands. As my job I make websites. I study Artificial Intelligence.
