Emergency Ductwork Crimper
2,239
11
Posted in WorkshopTools
Introduction: Emergency Ductwork Crimper
About: Was it you or I who stumbled first? It does not matter, the one of us who soonest finds the strength to rise must help the other. - Vera Nazarian, The Perpetual Calendar of Inspiration
If you're working on HVAC or dust collector piping and you need to convert a female end to a male fitting, the traditional solution is to stop what you're doing, run out to the home center and buy a crimper made for the purpose, and watch your $30 investment sit in a drawer the rest of your life. Some tips advocate deforming the perimeter with a pair of needlenose pliers, possibly resulting in an ugly, uneven, ill- fitting job. Try this easy, no cost method instead for a more professional looking and better fitting joint.
Step 1: Crimp With Style
Grab a pair of wide mouth pliers and tape two cutoff brads to the lower jaw and one centered between on the upper. Now you have a reasonable facsimile of a proper crimper tool, and for 2 or 3 crimp jobs you just saved some serious time and money.
To use, just orbit the tool around the mouth of the opening trying for an even, undulating result. You should get enough shrinkage to fully and securely insert the new male connector end into the next female section.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    2 Comments
    I crimp quite often using the needlenose pliers. This tip is very much appreciated.
    Thanks
    $30 saved.......now if only I could find free workarounds for all the other stuff in life I'd be rich!
