Emergency Fire Safety Sprinkler Using LM35 and LinkIt One
Published
Introduction: Emergency Fire Safety Sprinkler Using LM35 and LinkIt One
What will you do when accidently your Home,Office,etc catches FIRE!!
Here's one solution to help control the Flame! So,Today We are going to Implement Emergency Fire Safety Sprinkler Using LM35 and LInkIt One board.
LM 35 gives Linear proportional output with High precision within a great range of -55'C to 150'C.
Step 1: Requirements
LinkIt One Board.
LM 35
Connecting wires(Female-to-Female)
Use Motor controlled pipe for Sprinkler through a 5V relay.
Note:Choose Motor such that less current is sinked through it and does not damage the relay
Step 2: Connections
LM35 with LinkIt One:
VCC-5V
GND-GND
OUT-A0
After these pin connections, Connect the remaining parts as shown in the diagram.
Step 3: Coding
Here's the code. Compile and Upload It and By doing so the emergency fire safety sprinkler is ready to RESCUE!!
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    Great design for a fire system. The LM35 sensors are small and cheap enough that you can put them all over the place.
