Emergency Power Supply
5,551
19
8
Posted
Introduction: Emergency Power Supply
ok this is my first instructible so bear with me , i made this on such short notice because i needed a Power source to use on camping trips so i hope the time i spent on it helps somebody since i didnt have a box t put it in so I used Electrical tape
plus i also can use it when the power goes out i can use it to charge a Cell phone or run the light that i Have Taped on it
materials needed
Sealed Lead Acid Battery (From An Old Dead UPS I already Had, i think its a 7Ah But im not sure )
14-16 Ga Wire (Wally world)
cigarette lighter or Aux power outlet (Wally world)
12v Light (Bass Pro Shops $16.49 )
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_67660____SearchResults
And A Switch (Harbor Freight $2.99) (NO LONGER CARRIED)
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66306
Heres One Simular from BASS PRO
http://www.basspro.com/PushPull-Switches/product/8921/#chart-container
Tools Needed:
Philips Screwdriver
Electrical Tape
Wire Stripper/crimper
Note: Use Common sense, make sure your connections are good I am NOT responsible for any Damages due to Shorts, reverse polarity (Fried Electronics in General)......................
And Im sorry that some of my pictures are poor thats because my camera's battery died and it would have taken too long to charge so i had to use my cellphone camera
Step 1: Battery
Since I Already Had My Wiring Made ILL skip that step.
prep your battery
For wraping tape it works best if you turn the battery on the side that you wouldn't be using or have someone hold it for you.start with your aux outlet and switch. wire the Aux outlet directly to the battery then connect your wires to the switch for other opitional accessories like a Light or something
Step 2: Wiring
Well this one is self explanatory I've written a wiring diagram for it
Step 3: Finshing Up
With everything in place and taped on (temporary) test it with cell phone car charger
Then add an Inverter too
Future Improvements:
Put the Battery in A Box
Mount the AUX Socket,the switch &the light in/on the Box
Maybe A Solar Panel http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41144
And Charge Controller http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96728
Plus I didnt have to recycle the battery just the old dead UPS components
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
8 Comments
You could add one of the small (100 watt) 12 VDC to 110 VAC converters and power a small device...
I have already have a 75 Watt /100 watt Peak inverter i use for my Laptop but i think this battery im using has a low amp hr. but since money was tight when i built this i couldnt buy another one
the Converter which is an Inverter is pictured
How do you re-charge the battery? I made one of these last night, and came to instructables looking for a charge circuit. Good build.
I actually made 2, one with a single battery, and a second with two batteries wired in parallel. I have 50-60 of these batteries lying around (IT guy) and like the idea, I'm just trying to figure the best way to replenish the depleted batteries.
i used a 12v battery charger from bass pro.....
http://www.basspro.com/6V/12V-Battery-Charger/product/49377/-924244
how long does the battery last
if im using my inverter with a load, about 10 to 15 mins
but if i use the LED Light, about 3-4 hrs
and a 12v cell phone charger, about 30 to 45 mins
but the battery i am using came out of an old dead UPS so it was only designed to hold a charge for 10-15 min for a computer and a monitor
