3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Emergency light with steampunk technology
Hello everybody
In one of my former instructables I explained the way to work with High Voltage by using a flash module of an disposal camera.
Now I want to present you an project which followed this. All the photos had been taken and the different components had been put togtether. Then a new idea came in my mind. I tried to put the three components: an CFL-Tube, an modified electronic from an disposal camera, and the two AA batteries for using 3,0 Volts toghter in one big PET -Preform Tube to create an Emergency Light.
So Look at my "Emergency Light Torch":
It creates enaugh light to find your way out if it is dark inside a house or if your car is broken down on outside a city or village or so. Even when you sleep in a tent while your are doing camping you can use it very well.  I only changed the switch and all other parts fit closed together.
To show the way how it works I decided to give you a glance without the steampunk wrapping with a copper tube and some brass elements. This outfit will follow later;-)))
Step 1The circuit
The circuit
You probably remember this picture fom my other instructable:
High-voltage-power-supply-for-Nixies-CFL-Neon-Glow lamps....
In this emergency torch I used all of these parts you see on the picture except the switch.
55 comments
1-40 of 55next »
Mar 6, 2012. 8:23 PMpro5200 says:
can i use 3 volts, with button cell CR2032 ?
and how long durability?
I want to form a smaller lights & cute
Feb 22, 2012. 9:08 PMpro5200 says:
awesome, this is what I was looking for.
but I have 2 questions:
1. with 2 AA battery how long the lamp can be lit?
2. I think CFLs are that require ventilation for light, could later be fast off the lights? because the heat inside the tube
Feb 24, 2012. 12:25 AMpro5200 says:
oh so so,
I get, so hot from the circuit ...
if 16-20 hours, it is more than adequate for emergency needs, your work is great.
thanks for sharing :)
Dec 18, 2011. 4:41 AMTron1966 says:
Excellent project!
- though suggest you keep it under lock & key if you have any lady folk staying over :-)
Dec 6, 2011. 4:09 PMWinged Fist says:
Junophor – Congratulations on your well deserved recognition in the "Pocket Sized Challenge"!
Nov 18, 2011. 1:23 AMRehmatullah says:
is it 220 volt saver ?
how u convert it dc ..
Nov 23, 2011. 1:07 PMshamelessand1 says:
la lampara de gas de mercurio no es como la bombilla de luz, la de mercurio lleva un circuito electrico con un transformador que transforma de 220v a 3v!! eso!
Nov 20, 2011. 8:31 PMRehmatullah says:
i really didn't understand ???? :(
Nov 23, 2011. 2:10 AMrhowind says:
is there any pressure from the bulb heating the air? i would like to make one.
Nov 21, 2011. 7:02 PMeight says:
Be proud of yor project.
You did really well sir !
- Dave
(Greetz from Western Australia !)
Nov 21, 2011. 10:17 AMAdmiral Aaron Ravensdale says:
Good Job and the bulb is very save inside the tube!
I think it can be used in many cases...
Nov 19, 2011. 4:33 PMbook man says:
insted of the 2 aa could you use just a 9 v battery and by the way and awsome instructable
Nov 14, 2011. 7:45 AMWinged Fist says:
Congratulations on another ingenious steampunk design! I wonder if with a shorter bulb and some minor modifications, this might fit in a mason jar, like my Steampunk Lamp Lanterna Antiga?
Nov 15, 2011. 12:19 AMWinged Fist says:
Junophor,
My thought was not to build your light into my lamp (which already has electrical power from the plug) but rather to build your device as a mobile lantern inside of a mason jar. I guess one problem would be drilling a whole through a glass jar.... Maybe if a PVC or similar base was used, a switch could go in there, and a jar could be used to cover the bulb? Just a thought...
As far as adding a link in a comment, simply click the "Rich Editor" button above the comment box (after you've clicked "comment" or "reply"); highlight the section you want to link, and select the blue "link button" (second to last on the top row). Then paste the url address for the instructable (or website) you choose to link to. Viola!
(For further info, you can find a discussion of this process here).
Best to all the talented Steampunkers in Germany! Keep up the good work;-)
Nov 18, 2011. 5:12 PMSlim49 says:
drilling into glass.
an old trick is to get a copper or brass pipe , cut slots down into the active end with a hacksaw, a blade worth of depth.
fill it with tooth paste and sand & keep it moist while drilling. MUST keep heat down.
you now have a abrasive drill bit! go slow.
Mr. Steve
Nov 17, 2011. 1:54 PMboston7513 says:
This is a cool instructable!
I was just thinking that you could get one of those solar lights that you see at the dollar store and use the Photovoltaic parts to charge your lamp
Nov 17, 2011. 7:59 PMboston7513 says:
ya they had a bunch at the Dollar Tree here in Hanover Ma
Apr 25, 2012. 8:00 PMWascopirate says:
it's good to see someone from my area on instructabes, i'm from wasco
Nov 17, 2011. 8:48 AMA_Steingrube says:
Neat circuit, and awesome gizmo, but this isn't steampunk. The basis of steampunk is to imagine how today's and the future's gadgets would work without electricity. If you are showing off batteries, wiring, and light bulbs, it completely defeats that idea.
Congratulations on the neat project though :)
Nov 17, 2011. 6:09 PMtechno guy says:
Isn't steampunk like modern technology with a Victorian style?
Nov 17, 2011. 4:09 PMscotth61 says:
Re-read his introductory material. He stated "To show the way how it works I decided to give you a glance without the steampunk wrapping with a copper tube and some brass elements. This outfit will follow later;-)))"
Nov 15, 2011. 3:50 PMkillbox says:
Where did you get your large sized bottle blank (test tube?)
Nov 17, 2011. 7:02 AMchrwei says:
a google search for "PET Preform Tube" is only yielding the china suppliers with large minimum orders required. Do you know of a place to get them in small quantities?
Nov 16, 2011. 1:33 PMkillbox says:
Yes i know its a preform bottle blank, I was wondering where you got one large enough to fit a florecent bulb in like that. all I can find are smaller standard coke bottle necked ones.
Nov 18, 2011. 2:25 AMMadrigorne says:
http://www.cacheboxstore.com/products/Soda-Bottle-Preform-Cache.html
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
170
Author:Junophor(www.Dampfkraftlabor.de)
I love to invent and create new things in a "steampunk styled way" working with brass, copper, vulcanized-fiber, brass gears and (ply)- wood. On one side I am fascinated in neon lights and small elec...
more »
