Encapsulated Memory Stick
1,845
7
Published
Introduction: Encapsulated Memory Stick
About: I have no interest in friends, women or men. Although friends are nice to have, I really could not care less what anyone thinks of me and I can get on perfectly well without friends. Getting drunk, wasted or...
Here is how to create a cool style of memory stick. The electronics are well protected yet still visible. The memory stick is encapsulated in extra strong epoxy which dries to a rock solid clear finish.
You will need:
Araldite Precision extra strong or any other high quality 2 part epoxy.
A memory stick. I got a genuine 8Gb one here for £3.73. It was tested with h2testw.
http://www.ebay.co.uk/itm/320931299551?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
A heat source. A halogen light or a heat gun will do.
Step 1: Mix the Epoxy
You will need a decent amount. Put a blob of each part of the epoxy onto a card and mix it while holding the card over the heat source. This makes it very easy to mix and results in a better finish.
Step 2: Apply the Epoxy
Carefully coat all the components in epoxy. Do this away from the heat as it will be easier. Make sure that plenty is applied to the end with the plug to make it more reinforced.
Step 3: Heat Each Side
Use the heat source to heat the epoxy. This will remove most of the bubbles and let it flow in around all the components. The epoxy will also become clear as the bubbles disappear. You can apply the epoxy to the other side when the first side begins to harden. This will take about an hour if you keep it under the heat.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
