Encrypt Communication of LDAP Authentication Between Raspberry Pi Devices Using Transport Layer Security (TLS)
Introduction: Encrypt Communication of LDAP Authentication Between Raspberry Pi Devices Using Transport Layer Security (TLS)
The LDAP authentication can be made secure by encrypting the communication between LDAP server and client. Encrypting the communication may sound unnecessary if your two devices are in a private network such as a home network. However, your son, daughter, sister, brother or parents might be an evil genius and scheming to steal your password. So it may be worth your time to encrypt the communication of the LDAP authentication.
Complete the following instructables:
"Make Raspberry Pi into a LDAP Server to Store User Account Data and Password" instructable
"Make Raspberry Pi do LDAP Authentication" instructable;
We need to have at least 2 Raspberry Pi runnung Raspbian OS. For simplicity, I will call the 2 Raspberry Pi as Rpi1 and Rpi2:
Rpi1 will have:
  • LDAP server with user account database and automounter maps
  • NFSv4 server sharing home directories
Rpi2 will have:
  • Automounter mount users' home directory located in Rpi1's NFSv4 server but now it looks up autofs maps in LDAP server of Rpi1
  • LDAP authentication using Rpi1's LDAP server
This instructable will show how to:
  • Install CA certificate
  • Create and install certificate for LDAP server
  • Configure client to do TLS authentication
  • Test
The following are data of the 2 Raspberry Pi:
Distributor ID: Debian
Description: Debian GNU/Linux 7.8 (wheezy)
Release: 7.8
Codename: wheezy
Linux rpipro.example.com 3.18.9+ #767 PREEMPT Sat Mar 7 21:41:13 GMT 2015 armv6l GNU/Linux
LDAP authentication with nss-pam-ldapd http://arthurdejong.org/nss-pam-ldapd/setup
Debian - Configuring LDAP Authentication https://wiki.debian.org/LDAP/NSS
Debian - Setting up an LDAP server with OpenLDAP https://wiki.debian.org/LDAP/OpenLDAPSetup
Ubuntu - OpenLDAP Server https://help.ubuntu.com/12.04/serverguide/openlda...
Step 1: Make Raspberry Pi Into a LDAP Server to Store User Account Data and Password
Step 2: Make Raspberry Pi Do Unsecured LDAP Authentication
Complete he steps in the "Make Raspberry Pi do LDAP Authentication" instructable.
Ensure that this step is successful before moving to the next step. The reason being if LDAP client failed to authenticate in unsecured communication, it will also failed to authenticate in secured communication.
Step 3: Install Transport Layer Security (TLS)
Open terminal in Rpi1
Install the gnutls-bin and ssl-cert packages:
sudo apt-get install gnutls-bin ssl-cert
Step 4: Install a Certificate Authority (CA)
Certificate Authority is needed to sign subsequent X.509 certificates.
Create a private key for the Certificate Authority:
sudo sh -c "certtool --generate-privkey > /etc/ssl/private/cakey.pem"
Create the template file /etc/ssl/ca.info to define the CA:
sudo vi /etc/ssl/ca.info<br>
cn = Example Company
Create the self-signed CA certificate:
sudo certtool --generate-self-signed \<br>--load-privkey /etc/ssl/private/cakey.pem \
--template /etc/ssl/ca.info \
--outfile /etc/ssl/certs/cacert.pem
Step 5: Install a Certificate for the LDAP Server
Make a private key for the LDAP server:
sudo certtool --generate-privkey \
--bits 1024 \
--outfile /etc/ssl/private/ldap01_slapd_key.pem
Create the /etc/ssl/ldap01.info info file containing:
vi /etc/ssl/ldap01.info
organization = Example Company
cn = ldap01.example.com
expiration_days = 3650
Create the LDAP server's certificate:
sudo certtool --generate-certificate \
--load-privkey /etc/ssl/private/ldap01_slapd_key.pem \
--load-ca-certificate /etc/ssl/certs/cacert.pem \
--load-ca-privkey /etc/ssl/private/cakey.pem \
--template /etc/ssl/ldap01.info \
--outfile /etc/ssl/certs/ldap01_slapd_cert.pem
Step 6: Add the Certificates Into Config Database of LDAP Server
Create the file certinfo.ldif with the following contents:
vi ~/certinfo.ldif
dn: cn=config
add: olcTLSCACertificateFile olcTLSCACertificateFile: /etc/ssl/certs/cacert.pem
add: olcTLSCertificateFile olcTLSCertificateFile: /etc/ssl/certs/ldap01_slapd_cert.pem
add: olcTLSCertificateKeyFile olcTLSCertificateKeyFile: /etc/ssl/private/ldap01_slapd_key.pem
Add the certificates to LDAP server so that slapd recognize the certificates via the slapd-config database:
sudo ldapmodify -Y EXTERNAL -H ldapi:/// -f ~/home/certinfo.ldif
Check that the certificates are acutally in LDAP config database:
sudo ldapsearch -Q -LLL -Y EXTERNAL -H ldapi:/// -b cn=config olcTLSCACertificateFile=*
Output of above command:
dn: cn=config
objectClass: olcGlobal
cn: config
olcArgsFile: /var/run/slapd/slapd.args
olcLogLevel: none
olcPidFile: /var/run/slapd/slapd.pid
olcToolThreads: 1
Configure ownership and permissions:
sudo adduser openldap ssl-cert
sudo chgrp ssl-cert /etc/ssl/private/ldap01_slapd_key.pem
sudo chmod g+r /etc/ssl/private/ldap01_slapd_key.pem
sudo chmod o-r /etc/ssl/private/ldap01_slapd_key.pem
Check that openldap user belongs to group ssl-cert:
id openldap
uid=107(openldap) gid=110(openldap) groups=116(ssl-cert),110(openldap)
Open a new window in terminal emulator
Monitor syslog file to see if the server has started properly.
tail -f /var/log/syslog
Restart OpenLDAP and quickly monitor syslog in the other window:
sudo service slapd restart
Step 7: Install CA Certificate on Client(s)
Recall that CA certificate was created in Rpi1.
Open terminal emulator on rpi1
Copy CA Cert in rpi1 to rpi2 (192.x.x.x is your Rpi2 ip address)
sudo scp /etc/ssl/certs/cacert.pem pi@192.x.x.x:/home/pi
Open terminal emulator on Rpi2 or ssh into Rpi2
Copy the CA Cert to a more appropriate directory
sudo cp /home/pi/cacert.pem /etc/ssl/certs/
Step 8: Turn on TLS in Nss-pam-ldapd
Open terminal emulator on rpi2 or ssh into Rpi2
Configure connection daemon like the following:
sudo cp /etc/nslcd.conf /etc/nslcd.conf.pristine<br>
sudo vi /etc/nslcd.conf
uid nslcd
gid nslcd
uri ldap://ldap01.example.com
base dc=example,dc=com
ldap_version 3
#Choose TLS to encrypt connection
ssl start_tls
tls_reqcert demand
# Set the path to the CA certificate that was obtained from Rpi1 tls_cacertfile /etc/ssl/certs/cacert.pem
Step 9: Configure Ip Address Lookup of LDAP Server
Configure ip address lookup of ldap01.example.com
sudo cp /etc/hosts /etc/hosts.pristine
sudo vi /etc/hosts
ldap01.example.com 192.x.x.x #192.x.x.x is the ip address of Rpi1
Save the file
Step 10: Test
Reboot Rpi2
Enter name and password into login screen. Use our test user, john:
user: john
password: johnldap
If the desktop is loaded, then the LDAP authentication using TLS is successful.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
