This project is also documented on my website at: http://www.mbeckler.org/pneumatic_cannon/
Remove these ads by
Signing UpStep 1: Safety Warning!
If you only remember one thing from all my safety warnings, remember this: PVC shrapnel will not show up on an X-Ray. The doctors will have an extremely hard time picking all the plastic shards out of your body if something goes wrong. You have been warned.
organicengines adds a helpful reminder to keep your PVC out of direct sunlight, because the light will degrade the plastic and make it brittle. Be careful!
Yes, this could be a dangerous project. I'm not a lawyer, but I'd like to say that I'm absolving myself of all responsibility for your actions. If you decided to build one of these cannons, by all means have fun, but please be safe. I'm not responsible for anything except for fun. If any of the Instructables administrators or moderators feel this project is too dangerous for this website, I will gladly remove it as soon as possible.
Another safety point: This is a cannon, which is a type of gun. Guns are meant to be dangerous, they would be pointless if they weren't. If you have no experience handling guns, please be very careful with this project, and do yourself a favor and take a firearms safety course. It will be a good experience even if you never shoot a gun again. If you have experience with guns, please be careful regardless. When I went through hunter's safety, they taught us three important rules of firearms safety:
1. Treat every gun as if it is loaded, so always point it in a safe direction. This means not at you, your dog, or anybody standing around. Point it up in the air, or down at the ground.
2. Always keep your finger off the trigger (valve switch) until ready to fire. Enough said.
3. Know your target and what's beyond. Plywood, fences, and garage walls are not strong enough to stop some of the things you can shoot with this cannon. I've put clean holes through both walls of an empty 55 gallon steel drum, so know what's behind your target. Try to not shoot this cannon in residential areas, or use really low pressures and soft projectiles. Soft projectiles include rolled-up, wet socks (more on this later), water, and loose snow.
That being said, this cannon can provide hours of entertainment, as well as a bit of education, in projectile physics and the ideal gas law.
Visit Our Store »
Go Pro Today »
http://www.air-matics.com/Pneumatic_valve/
Well done! :D
http://www.spudtech.com/detail.asp?id=38
http://www.google.com/search?q=mod+a+sprinkler+valve
Someone should make an instructable for this...
I think it means that it is 10 times the Atmospheric pressure on Earth, which is 14 psi. Simple maths 10x14=140psi.
Search google/wikipedia to make sure...Wikipedia has a good table for comparing psi/atm/psig blah blah.
Google is pretty handy for these sorts of unit conversions:
How to use google search ror unit conversions
http://www.spudfiles.com/spud_wiki/index.php?title=Identifying_Pressure_Rated_PVC
And I get all my information mainly from a spudgun forum called http://www.spudfiles.com/
I am an active member there under the same username as here.
And I see that you made this instructable quite a while ago and I'm assuming your cannon has not blown up yet.
I find that surprising, though you probably dont have any scratches on the bell reducer and you most likely did a good pvc cementing job.
I myself have experienced DWV go boom, it isnt a joke.
And dont mistake me for a spudgun genious, im just a 14 year old that is experienced with these types of things.
If I get bored later, I'd like to look into the math to justify the "faster valves = further shot" argument.
They open 5x faster.
To find a tutorial go Here and Here
For the first one, click on design library and "Orbit watermaster modification"
To hopefully make the chamber a bit safer, I bought a 3" x 24" piece of galvanized pipe for 2 bucks and change. Something like this stuff
http://www.acehardware.com/product/index.jsp?productId=1274082&cp=1254880.1255015.1306408&parentPage=family&searchId=1306408
I plan to fill the space between the chamber and the pipe with wadding (maybe wrapping in old jeans!, and the putting 4 or 5 pipe clamps around the whole thing. More aesthetically pleasing that way too :)
http://www.apiplastics.com/pvc_pipe_furniture_pipe_coex_extrusion_capstock.html
The most apparent point affecting performance was the volume output of the solenoid. The solenoid aperature was quite small in our cannons. I would suggest using two or more in parallel to allow more gas to flow per unit time.
Our favorite thing to do was to shoot water colums. This was very dangerous because of the mass of the water column in the cannon: a VERY surprising amount of reaction force "gun-kick" due to the mass of the water being propelled out of the system. However, watching a three-inch column of water rise 15 ft into the air is quite an aesthetic :)
If you want a safer way to play with it, you can turn it into a downright nasty watergun by getting a rubber cap and cutting an astrisk of slits into it. Use a funnel to fill the barrel with water, and the cap will hold it in until you fire, and the pressure will flex the rubber outward turning it into a nozzel. Just make sure you tighten down the collar on the rubber cap really well. And still don't fire it at people! Mine had a smaller chamber vs barrel volume than yours and anything over 60 PSI would make it shoot clouds instead of a water stream.
