Step 8Ammo, Firing, and Results
Filling your barrel with water right from the garden hose is also quite fun, good in squirt-gun fights. Of course, try to keep the barrel mostly upright.
In the first picture, you can see my brother preparing to ram a wet sock projectile down the 1.5" barrel. We used the other barrel, the 0.5" barrel, as a ram-rod, although nearly anything long and thin will work.
Video One: Here, my brother and I are shooting one of the aforementioned wet socks using the 1.5" barrel. We are standing behind our garage and shooting into the neighbors yard. The sock landed by the small shrub that you can see in the video. The cannon was pressurized to about 40 psi.
Video Two: Here, my brother and I are shooting small plastic beads with the 0.5" barrel. Since the beads were smaller than the inside diameter of the barrel, and didn't form an air-tight fit, we used a small piece of paper towel as wadding. You can see the paper towel floating down to the ground, a few feet past the barrel. The beads all landed near the same shrub the sock landed by.
Bolts: My brother discovered that a small bolt fit nicely in the 0.5" barrel. He shot it into a piece of plywood. The bolt drove through the wood about 0.25 inches. Please don't shoot bolts at people or houses.
4
comments
Add Comment
Add Comment
