Energy Efficient Buildings Built on Bolt
262
6
Posted
Introduction: Energy Efficient Buildings Built on Bolt
Specially in offices and other institutions such as schools, colleges and even homes, sometimes we leave the room without switching off the lights and other electronics equipment. In offices, colleges etc. at the end of the day, somebody has to physically check each room whether the lights are switched off or not. Now there’s one thing, either you switch off the lights of entire building by switching off the MCB but that wouldn’t solve the problem if someone wants to use a particular room.
So, I provide you a solution in which a user is provided with an interface in which he can switch on or off lights of any room just by a single click where the entire system (appliances and Interface) is connected with Wi-Fi.
Step 1: Materials
Materials-
1 Inventrom Bolt IoT Platform
3-4 LEDs
Jumper wires
Soldering Iron
Wi-fi Connection
Software-
Html, CSS and JavaScript
Step 2: Schematics and Circuit Diagrams
Bolt Iot Platform is sa,e as Arduino Uno but with an attached functionality of connecting to a network
Bolt has 7 Digital Pins, Rx,Tx, 3 Analog pins and 2 Vcc and 2 gnd pins
Connect +ve terminal or three LEDS with 3 pins(pins 0,1,2) and -ve terminals to GND
Connect Bolt and your computer to the same wi-fi Network. for other configurations help access inventrom bolt website.
upload the following code into the bolt.
always save the code as index.htm
bolt iot generates dynamic IP every time so check that ip using Fing Application and access that ip
the current IP for my bolt is 192.168.1.66
access 192.168.1.66/developer to upload the program and then access 192.168.1.66/reset to reset the bolt
Step 3: Code
(apply CSS according to your needs)
<html>
<head>
<body>
<center>
<h3> HOME AUTOMATION / ENERGY EFFICIENT BUILDINGS </h3>
<h4> Room 1 </h4>
<button><a href="http://digitalWrite?pin=0&state=HIGH"> LIGHT ON </a></button>
<button><a href="http://digitalWrite?pin=0&state=LOW"> > LIGHT OFF </a></button>
(you can add for three rooms like this)
</center><body></html>
Step 4: Working
As soon as the user clicks on the button to turn the light on, and since the interface as well as the Bolt is connected in the same network, the bolt would generate the click of the user and produce the specified results.
this system can be easily implemented and a better interface could be built which would allow a user to easily control the electronics.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
Bolt seems like it would be a useful platform for microcontroller projects. I am going to have to check it out.
