loading
Step 7: State E-bike Laws Must Change!
Washington state e-bike laws are not adequate for heavy duty cargo bicycles.
The maximum power allowed for a motorized bicycle is 1500 watts at the drive axle. The motor will have to draw more than that.
1500 watts will move 600lbs (total combined weight) up an 8% grade at about 13mph if using the right gear. Unfortunately most people think they need as much speed as they can get. So if a moped bike had a gear box with at least two gears, there would not be a problem.
But if you want to use a fixed gear drive the 13mph is the maximum speed the vehicle would drive at. So the laws should reflect the amount of gear reduction your vehicle has; ie: for 20mph you need about 2200 watts to move that 600lbs up an 8% grade.
The wide torque band of electric motors, particularly the torque available at low RPM, eliminates the need for more than one gear.
Set the single fixed reduction gear at the highest speed that the available power will still be capable of driving your fully loaded vehicle up your steepest hill. Then if you still need a faster gear for less strenuous terrain, you can think about using a two speed gear box.
However it would be easier to just use a gear box, not to exceed 20 or 30mph. And have your vehicle examined for stop-ability with a total combined weight of 800lbs.
The real problem is people's insane lust for speed. They want to be able to turn their bicycles into illegal motorcycles. Well there are better ways to kill your self.
I've been working on a little idea using a hybrid electric and hydraulic drive system... it seems to fit right in line with what you're talking about here. if anybody has any information about drive by hydraulic systems please get in touch with me. my idea is to have a tandem device with electric motor and hydraulic drive where the electric motor can power the hydraulic system or the hydraulic system can assist or power the electric motor making an all-inclusive assembly. then if you have one, you can make a unicycle. 2, you can make a motorcycle. 3 or 4, you can make a trike or car. more you can make a semi / hauling / commercial type of vehicle...
<p>I would really like to see more info on that project. Do you have a blog?</p>
<p>I do not. so far i've just been tinkering and planning. need metal shop and hydraulic experience/support to go further</p>
Very useful information<br>Thank You
<p>Very interesting information! Thanks for sharing!</p>
About This Instructable
1,672views
26favorites
More by Professor Prodromal:Engineering a Power System for heavy cycle-trucks and velomobiles
Add instructable to:
