3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
English Longbow
English Longbow
It was about time I tackled the project of a period-type English Longbow, and with much inspiration and guidance from alanesq's website (http://www.alanesq.com/bsb.htm), I was able to complete a simplified version of the English longbow.
The final product is about 6' 4" with a low draw weight of about 25 lbs at 24 inches, perfect for simple target shooting. As you can see, I wasn't going for a battle ready, armor-piercing warbow or anything. It looks nice, took about 5 hours to make, and was under 10$. This is the perfect bow for a nice weekend project.
**DISCLAIMER** This bow is, in fact, a weapon! I take no responsibility for how and in what fashion these instructions are used. A bow is dangerous; don't shoot arrows at anything you don't mind hurting or destroying.
For a video of the bow in action, check the link on the last step!
Step 1Materials
Materials
This is a VERY cheap project...if you already have the necessary tools, that is. Most, if not all, of the tools and materials can be found at a Home Depot or other similar store.
Tools:
  Angle Grinder (with sanding attachment)
  Sand Paper
  Hand File(s)
  Clamps (optional)
  Wood glue
Materials:
  6-7 Feet of 2"x1" Red Oak
  6-7 Feet of 2"x1/4" Pine***
  Twine (for the string)
***I made the assumption, not very educatedly, that a pine "belly" on the bow would handle the compression much better than the red oak, seeing as pine is much less dense than red oak. Well in my haste, I got cedar instead of pine, which resulted in a very useless "belly" that did not handle compression very well. In my last couple of steps I included a picture of the...consequences...of a cedar "belly".
25 comments
Apr 2, 2012. 12:10 AMwodloo says:
nice bow im currently carving a bow from some sticks in the bush i see how that works but it will be completely hand crafted so if you dont want to take your time making it i suggest not.
Jul 21, 2011. 1:30 PMninja of suburbia says:
Props for making the attempt to make a bow, but you seem to have mixed some things up.
The belly is the part of the bow that rests against your palm. A good longbow is traditionally carved from a single piece of yew. The bow is carved in such a way that the heartwood forms the belly of the bow, and the HARDER wood thus resists the compression and adds a vicious snap to the bow while the sapwood forms the arms and the back of the bow, providing the main launching force. Once again, YOU DO NOT WANT A SOFT WOOD FOR THE BELLY OF THE BOW. But other than that, well done.
Jun 28, 2011. 2:31 AMbubblegum12 says:
how far does it shoot?
Jun 24, 2011. 11:20 PMyellerakern says:
nice bow.i am a newbie with all this computer stuf.this is my first time on this website i find it great.i also am in the process of makeing a bow.it's not my first,i gave away a fiew to kids in our family and show them the dangers of such.i have 4 pieces of hickory that is ready.i cut a 7 foot hickory log and split it in 4 pieces,they are dry now and i will begin saturday on my project.wamt to use this bow season for deer,will keep in touch.yellerakern.
Jun 14, 2011. 7:41 AMsmallebee says:
the ripples are where the seadar is spliting in the only direction posible. i dont advise doing this often as the damage may add up and fail unplesantly
10$=7£ verry good build.
Jun 13, 2011. 5:26 AManibioman says:
when tillering do you just sand the belly?
May 30, 2011. 11:45 AMbowmaster says:
Very nice, I have wanted to make a bow for some time now. If you want to make it more authentic YEW should have used a different wood.
May 30, 2011. 11:31 AMkstarr says:
I have a load of nomal oak do you think it would be suitable?? gr8 instructable :) thanx 64
May 30, 2011. 6:07 AMmathieulj says:
Good job. I made one like this using a hand plane and sandpaper a little while back. One thing I want to add though (forgive me if you mentioned it and I didn't see). Pine is great for starting out since its cheap and easy to work with but I find (as do others) that it is a very poor wood for bows. It works but the end result has more power and lasts longer with other woods. So by all means, start with pine, but keep in mind you'd be better off with another wood once you get the hang of bow making.
May 27, 2011. 8:24 PMpaintboy360 says:
Does the bow need to be oiled at all?
May 29, 2011. 6:55 AMwhitewolf88 says:
not necessarily, but it will look nicer and be more weather and stain (ie dirt) resistant. if you use a laminated technique it'll bring out the different grains in the woods.
May 29, 2011. 10:53 PMpaintboy360 says:
Ok,
thank you!
May 29, 2011. 6:54 AMsplazem says:
Very cool. I love archery.
Apr 28, 2011. 10:48 PMrandomhand says:
Aren't English longbows exclusively yew tree wood? Isn't it a standard longbow if its not yew? i have heard lemonwood makes a good longbow
May 27, 2011. 7:14 PMCaym says:
i think the difference between an english and standard is that the english if you look at a cross section is in the shape of a D
May 27, 2011. 4:27 PMcap n crunch says:
they were primarily yew but other woods were used such as elm and ash
Jan 10, 2011. 12:08 PMleendertbob says:
Find out which wood can be compressed and which wood can be stretched.
It's all on Google and you know what wood to use to get an English longbow.
Dec 15, 2010. 7:17 PMAnhan12 says:
maple is my favorite wood for making bows. i made a maple bow a couple of weeks ago for only 13 dollars, and thats with a 6 dollar string from gander mt, so the bow only cost 7 dollars!
Nov 15, 2010. 6:32 PM503sPzAbt says:
Is it possible to use poplar, cherry, or white ash inplace of pine? I've heard this a few times but I am not sure this is true.
Oct 5, 2010. 6:05 PMDon,t try this at home says:
Can i have the dimensions of you bow i need to know the end of it were you string it how thick that is and how wide.
Oct 6, 2010. 9:47 AMspenfisher12 says:
25 lb at 14 inches of draw 1 25 lb is nothing 2 28 inches is where its draw weight should be mesured
Oct 6, 2010. 6:50 PMLeOSSJ2 says:
Hi!
I really liked your bow, i'm some kind of bad for the wood working, but, this is my favourite instructable of all of this contest, so..
You have my vote!
Goodbye!
Oct 4, 2010. 4:25 PMrimar2000 says:
Good work! When I was a kid, at Robin Hood age, I was crazy for bows and crossbows. One of these had plenty of power for my little boy's view. The iron headed arrow sinked in an old wooden door, and had to move sideways several times in order to remove it. I used paradise tree wood, because at home had one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
130
Author:ineverfinishanyth
I enjoy building and inventing; I have a specific interest in medieval and roman armor and weapons. I am a student in highschool currently and hope to study Mechanical Engineering in college at BYU. I...
more »
