3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Enhance Halloween Props - Rats
Step 5Other Enhancements
Other Enhancements
Often the toys/props from these cheaper stores aren't produced with quality in mind so some of the paint may not be lined up. Often, the whole prop may be glossy, or more frequently have a matte finish. (This one was glossy as you can see...) The problem with the matte finish is the eyes aren't shiny like real, wet eyes are. Use a small quantity of the glossy sealant over the eyes, nose and toenails to add a little realism.
Casting lines.
Often these props also have lines from the molds. These may be able to be cut off with a craft knife. Check one on the underside of the prop to see if the underlying plastic is a different color than the prop itself. If so, you can trim these molding lines flush with the texture of the prop. If your cut reveals a different color, you will probably want to leave them - unless you want obvious lines or desire to paint them..
Alternate eyes
If you have a rat that is hard plastic and appears to be hollow, you can make the eyes glow, sometimes. First, find something that has a red LED on it - a toy, remote control, mini-flashlight, etc., and will fit inside the rat. Cut a hole in the bottom, pour in some of the gloss sealer and spread it around. This will make the insides nice and shiny and will reflect the light better - you can also use white paint as well. Carefully cut out the eyes. Insert the LED into bottom of the rat and turn it on. (Please do not use a light bulb - the heat in such a confined space can be dangerous!).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:peanutgnome
