3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Enhance the functionality of many screwdrivers.
Step 3The result.
The result.
Shown is the subtly squared tip, showing a distinct "X" in the cross section. This is what grabs the screw, and what you want to end up with. If in doubt, try it with a screwdriver you don't care too much about, periodically checking the fit with a few different types of screw heads as you grind it, and stop when you notice a distinct improvement in fit. I would be interested in feedback from other people as to whether they find this situation to apply as generally as I do, and from anyone who can explain why most screwdrivers sold suffer from this "pointy-ness" problem (is it just a matter of quality control? are they designed for ideal screws that no one manufactures?) and I hope this helps prevent a few mangled screw heads. If someone knows of a reason why this is a bad idea, please comment about that, too. Happy screwing.
1 comment
Dec 8, 2009. 11:05 AMbrmadeira says:
It may be because the manufacturers know that a lot of people don't know the difference between a #1, #2, #3, etc. Phillips. If they make a precise #2, it won't fit screws that need a #1 Phillips, so a lot of people would complain.
But more likely it is just sloppy fabrication techniques.
I have also ground down the outside edges of the wings, very slightly, just enough to give a square edge to them, they grip better that way. But the best technique is to buy the best quality magnetic tips that you can find.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:yawfle
i don't sleep till it's light.
