Entirely Wooden Scooter
Published
Introduction: Entirely Wooden Scooter
About: I like building things and breaking things and fixing things. I also like pie
This scooter is wooden.
Step 1: Wheels.
The wheels are the hardest part of the build, so I did them first. They must be perfectly round, or else you will be in for a bumpy ride. I cut them from 7-ply. I used a compass to draw the circles, and used the point of the compass to make a clear indication of where I should drill the holes.
Step 2: Base
I used a piece of 4"x1" 52cm long for my base. I cut a slot in one end, 3cm wide and 7cm long, for the wheel. I drilled a hole though the side of the base and used a 5" bolt to secure the wheel.
Step 3: Stem
I used a piece of 4"x1" 75cm long for this one. I cut a slit in one end, same as the base, and a 5cm square hole in it.
Step 4: Steering
I put two pieces of wood, each with a hole in the middle as my steering. Then i drilled a hole vertically in a piece of 2x2" and put it together with a bolt. I then secured it to the base.
Step 5: Done!
Overall, this took me about three hours to build and then an extra hour to fine tune it. It is very cheap, and a fun alternative to normal aluminium scooters.
Vote for me please!
Trasky
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    Great re built of a real classic old school scooter - great job
