Step 10Cutting your cover pieces
Lay your board out on the cutting mat and position your ruler based upon the dimensions you determined in Step 9 (picture 1). Hold the ruler tight to the board and make multiple light passes with your craft knife until you feel the cutting mat underneath. Because two of the dimensions repeat, you can always use the first piece cut as a stencil for the next, just be careful not to shave anything off of your first piece. Your cut pieces should look similar to those in Picture 2. Retain your scraps for later.
NOTE: The easiest and safest way to cut illustration board is to use multiple light cuts. This way, you get a clean cut, but if your edge turns out ragged, you can always sand it down with a little sandpaper.
Add Comment
