3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Envelope Book
Step 17Creating your spacers
For this step you will need the scraps of board from Step 10, the scraps of inner paper from Step 16, cutting mat, craft knife, metal ruler, and glue.
Because of the space difference between the size of your spine and the width of the bound side of the envelopes, you need to make spacers to insert the envelopes into the cover.
From the scraps of board, you should cut out strips of board that are the same width as the smaller sections of your spine and the same height as your envelopes. In my case that means 1/2" X 6 3/4". The illustration board I use is 1/16" thick; so I cut out eight strips (picture 1), four for each spacer making my spacers each 1/4" thick. You should adjust your spacers to the amount of envelopes you used and the size of spine you cut.
Glue the spacer pieces together into solid blocks using the glue. I use Elmer's Craft Bond gel because it is a tackier glue and drys quickly. If you run a bead of glue down the middle of a strip (picture 2) and then slide the other strip around on it, that helps the glue to coat both strips evenly. Just repeat that until you've made your two stacks of glued together strips.
Place the glued strips onto the scraps of inner paper and cut out pieces that are about 1" bigger on each side than the strips (picture 3).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:donovanbeeson
My friends have described me as a "postal pervert" because I love everything about mail. I have fascinations with Cold War culture, military design, espionage, hermits, religion, and typewriters. Old ...
more »
