3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mushroom Environment Control - Arduino Powered
This is my first Arduino project aimed at helping me with my other hobby which is growing oyster and shiitake mushrooms indoors.
In a nutshell, the controller takes in two temperature readings, 1 Humidity reading and 1 Co2 reading and triggers a set of four relays connected to mains power.
Intended to be connected to the mains are two heating pads, a sonic humidifier and an air pump (although the choice isn't limited to these of course).
Step 1Items
Here is the list of items I used for the project.
MAIN:
-Arduino.
-LCD Keypad shield.
- 7-12 volt power supply.
- USB cable (socket that connects to USB on Arduino).
-Box To house the whole thing.
-Veraboard/breadboard.
- 4x solid state 5v- 240v relays.
- Mains Power board with four sockets.
- Wires.
- Jiffy box to house inline socket/screws to connect Sensors.
SENSORS:
-Thermistors 10k   x2
       -Resistor 10k  x2
-HS1100 humidity reader
       - 555 timer (cmos type)
       - resistors: 576k, 49.9k, 1k and 909k
       - Veraboard/breadboard
      - Jiffy Box
      - Digital divide by ten Chip
-MG811 C02 sensor (I got a breakout board with op-amp amplifier built in. You can make it yourself, it is a high precision op amp set up as non-inverting with gain around 10).
       - Jiffy Box
ENVIRONMENTAL CONTROLLERS
- 2 x heating pads
- Sonic Humidifier
       - Aquarium Tubing
       - Air Pump (aquarium)
       - Plastic lunchbox (airtight)
       - HEPA Filter for Vacuum cleaner.
       - Plastic tub
- Aquarium Air pump
      - Aquarium Tubing
     - Plastic Lunchbox (airtight)
EXTRAS:
- Hot Glue gun
- Soldering Iron
- Screwdrivers
- Multimeter
- Drill
- Home brew larger.
47 comments
1-40 of 47next »
Jun 4, 2011. 9:02 PMjbark says:
Hi Anthony,
I'm new to electronic. I got my self cd4017 for the divider, can you please tell me where you the output from 555 goes to? Or how do I know which one divides. This one is tricky to follow.
By the way this is my very first electronic that's not a kit from Jaycar. I'm almost there with it but this one has got me stuck.
So I followed your instruction.
Cheers
Thanks
Jul 27, 2011. 5:40 PMricbordenave says:
Sorry... Ground are pins 8, 13 and 15. Thanks
Jun 6, 2011. 1:32 AMjbark says:
Thanks Mate
Jul 23, 2011. 9:03 PMthebestofall007 says:
Co2 too low??? You said "This system of air filtration is also used for the air supply when the co2 gets too low". Dont you want the co2 to be as low as possible?
Jul 14, 2011. 2:36 AMbsnob says:
i saw someone make a similar device a long time ago , but no co2 sensor though and they connected it to the lpt1 port of a pc to control it , but it was used for mushrooms , i wish i could find the site where i saw it he had a basic software he wrote for it and everything and he was even selling kits or providing exact part lists with item # and where to get them ,i was interested in makingg one of these for a greenhouse ,but with a pc control or interface and a data logger, anyone know where i could fing plans for something like that?i thought i sa it on the shroomery but i forget and a search there turned up nothing
May 11, 2011. 3:55 AMAsameea says:
Hi Anthony, I want to know the amount you paid for CO2 with singal conditioning as shown in the diagram.
As you told about that website, i have checked the product, its cost is around $35, but i want to know exact amount i should pay for delivery to India.
Hence i am asking you to tell me the amount you paid for the same.
Thank you.
Apr 7, 2011. 11:44 PMtsenarathna says:
Hi Anthony,
What sort of output data did you end up getting with the Parralax sensors? Great work btw!
Jun 25, 2010. 3:15 AMjustjonty says:
(removed by author or community request)
Mar 28, 2011. 10:38 AMjustjonty says:
Hey again... If you are interested in what we have been doing with oysters in Afghanistan, I have recently published a couple of instructables...
How to Grow Oyster Mushrooms Low Tech and
How to Grow Oyster Mushroom Spawn Low Tech
I have just constructed a hepa filter laminar air workstation to help with producing spawn... might like to try your instructable out with regard to our test growing room... Thanks again for sharing...
Jun 25, 2010. 11:16 PMjustjonty says:
Currently we are growing them in straw (which then, after harvesting, gets given to their animals)... the great thing is that they don't need lots of land and the locals love them (other types grow naturally in spring and in the mountains)... we need to get them reproducing the spawn to complete the cycle... we'll see how that goes... thanks again for your 'ible!
Mar 1, 2011. 5:52 AMratheeshbr says:
Can you please tell me from where did you got this CO2 Sensor in India?
Jul 15, 2010. 9:42 AMcarlossantiago says:
Very cool use of the arduio. It's a great start for your first time coding in "C". GuruSantiago Checkout my arduino projects here: http://www.youtube.com/user/ElectronicsIsFun And follow me on twitter @ElectronicsFun
Jul 15, 2010. 6:39 AMStaggarLee says:
I was thinking the same thing. I am building a similar project, and base my relay sircuits from this guide http://www.glacialwanderer.com/hobbyrobotics/?p=9
Jun 24, 2010. 8:50 AMwifigod says:
I'm very excited to see somebody working on a very similar project as me! :-D I do have one question, where did you buy the MG811 that came with the op amp board? I too made the mistake of buying just the sensor and couldn't get it to work. (I'm NOT an electronics person, but I'm trying to learn!) Thanks!
Jul 10, 2010. 12:46 PMksgeek says:
Very nice project. I am creating a home HVAC data logger. As a side note the documentation on the mg811 sensor is very poor. I have the sensor working, I am concerned about the temperature. Do you keep the mg811 heater on constantly, or preheat it before polling? If so is the sensor hot to the touch?
Jul 6, 2010. 4:43 AMtwhaley says:
That's, i'm doing it!
Jul 5, 2010. 10:44 PMClayfig says:
how is it all working out for you ? I would love to see a kit from you with all the parts to order
Jul 1, 2010. 9:08 AMtehjrow says:
Don't you need diodes to protect the arduino?
Jul 1, 2010. 5:27 PMsalesmonster says:
Amazingly thorough writeup. You have done a great job of marrying two wonderful hobbies. I've been considering putting together the mycology environment project that Make magazine had several years ago...but humidity and temperature were my concerns. These systems fit the bill perfectly. Thanks for taking the time to share.
Jul 1, 2010. 9:20 AMNamban says:
This is amazing! I would definitely make this. I never thought I'd actually find someone growing their own oyster mushrooms- I used to live in Japan, for about 3 years, and they have the BEST mushroom in the world there- ¨êó®, Eringi, or King Oyster Mushroom in English. They taste 100x better than portabellas or even good shiitake- but I can't find them on the east coast US anywhere! And they taste like buttered steak... I've looked forever, but can't find anywhere on the net for king oyster mushroom spores- does anyone sell them? They are so good I must grow them myself, since noone in my area of the world seems to sell them. Can anyone help?
Jul 2, 2010. 7:58 PMDIY-Guy says:
Namban said: "They are so good I must grow them myself, since noone in my area of the world seems to sell them. Can anyone help?" DIY-Guy relied: You want to grow "King Oyster Mushroom"? Try using a Google search like this- "King Oyster Mushroom" growing kit Then look at the results- http://www.mycosource.com/king_oyster%20instructions.htm Other sites also are out there. (Disclaimer: I don't work for these guys nor do I have any affiliation at this time.) Thanks for the food description- "they taste like buttered steak..." it sounds really good to eat!
Jul 2, 2010. 8:23 PMNamban says:
Thanks for the info. I'd done plenty of Google searches over the years, and nothing came up- these must be recent, as I would have found them before. And yes, they taste exactly like a good steak smeared with butter. They are incredible- if you ever get a chance to try them, take it!
Jun 24, 2010. 12:30 PMrt61 says:
I would like to learn how to grow oyster and shiitake mushrooms. Where should I start? Thanks!
Jul 2, 2010. 1:41 PMjoystik says:
Youtube is your friend. Also, check the torrent sites for "Growing Mushrooms" DVD.
Jun 24, 2010. 3:27 PMwifigod says:
Nov 30, 2010. 1:52 AMRaziel7 says:
DVDs and books are good starting points for learning about growing mushrooms, but will not teach you how to grow them well. Most of the material is somewhat outdated.
New methods conceived by mycologists and growers can be found at shroomery.org
Search the forums for all the knowledge you will ever need, plus it is free.
Jul 2, 2010. 3:12 AMarticice says:
just steal it from ED2K ed2k://|file|%5BPsilocybin%5DGrowing%20Gourmet%20and%20Medicinal%20Mushrooms-Paul%20Stamets-2000-1580081754.CV.pdf|36908319|D7C4B3A02C96D1823E012B22315E98CE|/
Jul 1, 2010. 1:23 PMKitoru says:
It'd also recommend it. It's very highly informative and contains a lot of species specific information that'd be difficult to work out for yourself. I'm loving this project. I started a similar project about three years back that used almost exactly the same methods. The only variance really is that I used a Wine Cooler as the case to battle blistering California temperatures and a Sensiron SHT11 combined temp/humidity sensor. Except my Arduino BT (Sparkfun accidently upgraded my order) melted down and I've been working on rebuilding another board from scratch. T_T; It's not going well~ One question though. Why the choice of Thermocouples over serial interface temperature sensors? I believe the prices are comparable, and serial interface is such a breeze to work with.
Jul 2, 2010. 2:28 AMhot-fresh-rider says:
Let us not forget the king of mushrooms the Maitake, proported to have health benifits in a different league to regular mushrooms. could this breed be cross bred with conventional mushrooms? Cheap regular mushrooms with awesome health properties? we can dream!
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:anthony_p1234
I pass the time by involving myself in small projects and watching youtube political discussions. I am a jack of all trades and master of none, and am good up until I have to house a project in a box,...
more »
