3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mushroom Environment Control - Arduino Powered
Step 12C02 Calibration
C02 Calibration
This one is difficult.
The way I went about this was to look at the current value of C02 ppm in the world today (yes it is going up!), it's around 400ppm. Assuming that it is a bit higher if you live in the city (my one is relatively clean) I assumed normal outside Co2 levels to be 500 ppm.
So I opened my window and after allowing the Co2 sensor to heat up I took a number of
Serial.println(carbonD[4]);
readings.
I averaged these out, and set my X1 value to equal this, my Y1 = 500.
The datasheet showed that the sensor maxed out at 10000ppm, so for my second reading I got some bicarb and vinegar put that in a plastic bag with the sensor and sealed it up and set the reaction off.
After a minute or so It reached its lowest reading using
so I used this value as my X2, my Y2 I set to 10000.
Now I solved to find M and C: (or use excell :)  )
y1 = MLogn(x1) + C
y2 = MLogn(x2) + C
And plugged these values back into the program:
#define Carbon_M -83.45
#define Carbon_C 768.62
By the way for this step I am not convinced about my assumptions made about X2 and Y2 values (or Y1 values for that matter :)  ), if anyone has some suggestions I am open to them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:anthony_p1234
I pass the time by involving myself in small projects and watching youtube political discussions. I am a jack of all trades and master of none, and am good up until I have to house a project in a box,...
more »
