3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mushroom Environment Control - Arduino Powered
Step 4Co2 Sensor
Co2 Sensor
Initially I had ordered an MG811 Co2 sensor by itself, after setting it up I couldn't make it work properly so I ordered one already on a board with an op amp amplifier built in.
I later found that the power supply I was running it with was faulty and the heating element in the Co2 sensor was running on overdrive.
Basically the circuit has the sensor hooked up to a non-inverting op-amp with roughly a gain of ten, and the heating element is supplied by a 6 volt voltage regulator. The set up is shown on the datasheet attached with pinouts of the sensor which is self explanatory, what isn't self explanatory is the graph on the datasheet which gives a totally inacurate picture of the expected output of the sensor.
Give it a test by placing a Multimeter on the sensor and breathing on it, it should change reading.
MG811Datasheet.pdf(595x842) 146 KB
4 comments
May 11, 2011. 3:55 AMAsameea says:
Hi Anthony, I want to know the amount you paid for CO2 with singal conditioning as shown in the diagram.
As you told about that website, i have checked the product, its cost is around $35, but i want to know exact amount i should pay for delivery to India.
Hence i am asking you to tell me the amount you paid for the same.
Thank you.
Apr 7, 2011. 11:44 PMtsenarathna says:
Hi Anthony,
What sort of output data did you end up getting with the Parralax sensors? Great work btw!
Mar 1, 2011. 5:52 AMratheeshbr says:
Can you please tell me from where did you got this CO2 Sensor in India?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:anthony_p1234
I pass the time by involving myself in small projects and watching youtube political discussions. I am a jack of all trades and master of none, and am good up until I have to house a project in a box,...
more »
