Step 5Connect the Arduino
The Keypad shield goes just on top of the Arduino.
Solder onto the shield the separate Thermistor voltage dividers inputs to Analog 1 and Analog 2, Analog 3 takes in the Co2 input.
Solder to digital 2 the Humidity input.
Solder on the power supply, I recommend 7 volts supply as the C02 reader needs 6 volts at least. I soldered the power supply onto the go between board and then soldered from there to the Arduino.
I fed the 6 volts to power the humidity sensor and C02 sensor directly(as the C02 board had a voltage regulator), but used the 5volt reference voltage from the Arduino for the temperature sensor voltage divider.
Add Comment
