Step 9The Humidifier
To keep the C02 levels low you would add a fan.
...But what to add to keep the humidity up?? A humidifier and here's how I made mine.
First I got a small tub and drilled a number of holes in the top cover, and one bigger hole in the center. Next you thread the sonic humidifier wiring through and seat the humidifier on the bottom.
In one of the holes I attached some aquarium tubing.
On the other end of this tubing was an air pump held within a airtight tub. The lid of the tub had a hole cut out and was covered by a HEPA filter. The reason for the HEPA filter is so that air going into feed the mushrooms isn't contaminated with bacteria and other fungi.
This system of air filtration is also used for the air supply when the co2 gets too low.
After putting water in the tub, turn it on and watch.
comments
Add Comment
Add Comment
