This is a massive instructable, containing over 430 photos for your viewing pleasure. The different stages of the renovation will be separated by title pages, where you'll find a list of the tools you'll probably need, and materials you'll likely use. Feel free to use any or all of the different sections in your own renovation as required.
Now for the disclaimer: I am not a general contractor, nor do I have any construction training per se. However, I'm a very handy guy, I read a lot of books and how-to websites, and got plenty of help from my elders. The information presented in this instructable is as accurate as I could manage, and chances are nothing will go terribly wrong. If you're ever unsure of what you're doing, then stop, step back, and take a few minutes to think about it. Read instructions over again or find a second opinion.
Now, grab your sledge hammer and demolition saw, it's time to get started!
Sections:
Planning and Permits
Demolition
Foundation Inspection
Repairs and Waterproofing
Insulation
Framing
Electrical
Ductwork
Drywall
Painting
Doors
Windows
Built-in shelving
Flooring
Baseboards and Trim
Final Steps and Conclusion
Remove these ads by
Signing UpStep 1Planning
First, draw a scale drawing of the space you're planning to renovate. Include the outside walls, interior supporting walls, existing doors and windows, existing ductwork, plumbing fixtures, and any other immovable objects in the room. You likely won't be touching these (and I won't tell you how!) so you'll have to plan around them.
Next you have to consider what the new space will be used for. Are you going to put in a bathroom? An extra bedroom? Perhaps a workshop or office... Take your time to really think about what you want to build down there. After all, it will be more or less permanent, so you want it to be a useful space for a long time. You should also resist the urge to carve up a basement space into a lot of small rooms - it will end up feeling like a dungeon.
Also remember that each type of room will have a few requirements stipulated by your local building code that you must follow. For instance, a bedroom will probably need a large window for egress (emergency exit) if there is no secondary exit in the basement. Take these requirements into consideration as you make your plans so that you don't get stuck later on (or worse yet, receive a failing grade from the building inspector!)
In this instructable I will be using my own renovation as an example. I started with an 11x22 foot space that was divided into two rooms, a workshop and an empty room. Well, empty aside from a rather quaint toilet stall!
Well done.
Steve
I have plans to do a bathroom this summer. Hopefully I'll find the time to do it!
I'm not sure how long they took to dry. Unused glue squeezed from the tube and left in the open air took about a day to get rock hard.
but dude, Roxul isn't fiberglass -- it's mineral fiber, so it doens't make you as itchy as fiberglass though. You still need the breathing / eye protection like you describe. :D
Think about it this way: a basement renovation is something you're likely to do once. It'll cost a few hundred more to pack in more insulation, but in the long run it's worth doing really well. The foam panels will likely give you your minimum R-value to meet code, but I'm a fan of exceeding code where possible.
