Epic Basement Renovation!
 by jeff-o
Featured
Step 4: Demoltition - Intro
Okay, NOW it's time for the fun part!
Tools you may require:
Sledge hammer - for taking down concrete block walls, for separating 2x4s, and generally hitting stuff really hard.
Large Pry Bar - for pulling nails and prying off drywall
Small Pry Bar - for pulling nails
A Large Hammer - for prying out nails, for hitting the pry bar, for smashing out drywall
Demolition Saw - for cutting through 2x4s and other framing members
Power drill - for removing screws
Side Cutters - for cutting electrical wire
Dustpan, garbage bags - for cleanup
Vacuum with fine particle filter - for cleanup
Angle grinder with masonry disc - for smoothing out concrete
Fan - for fresh air, and blowing dust out the window
Ear, Eye, Hand, Foot and Breathing protection - To save yourself from the Pain of a construction injury
Depending on how "finished" the space already is, you may need to rent one of those large garbage bins for all the debris. Smaller jobs, or rooms with little work done to them, may only require a lot of industrial-strength garbage bags. Find out from the city what you can and can't throw out in the regular garbage.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
