Step 3Installing The "Circle Maker"
Use a blade to open up the glass and plastic layers of the screen to get inside the Etch-A-Sketch.
Once inside, bore a hole through the back center of the Etch-A-Sketch, then quickly cover up the hole on the outside with duct tape. Then, poke the duct tape with your "Circle Maker" device. This ensure that when you're using the "Circle Maker" that none of the Aluminum Powder will seep through.
Once your "Circle Maker" is through the hole, try it out. Make sure you can move it around where the screen would be and make sure you can twist while applying pressure to the screen. Also make sure you can pull the "Circle Maker" away from the screen and that it doesnt interfere with the regular Etch-A-Sketch mechanics.
Once all those tests are complete you're ready to seal it up!
Add Comment
