3 Simple Ways to
Share What You Make
Other ways to share:
Adapt a clock today! Cheap trackers boost solar panel and solar cooker performance.
by
gaiatechnician
Alternative to Scheffler solar kitchens
by
gaiatechnician
Hot Pot is a great solar cooker, but was designed for the Tropics
by
shastalore
Kyoto trough solar cooker mimics a parabolic dish without a thousand cuts!
by
gaiatechnician
Solar parabolic cooker with the mechanical mathematician!
by
gaiatechnician
Tracking the sun! For the solar accumulating Barbecue
by
gaiatechnician
Making and using a "compound" parabolic solar cooker (Large project)
by
gaiatechnician
Solar Charging System
by
Electronics Man
Clock Based solar tracker experiment
by
gaiatechnician
DIY 2 bucket dripper tracker for solar cookers and solar panels is cheap and it works!
by
gaiatechnician
2,212
views
Comments: 21
Rating: 0
© 2012 Instructables
All Steps Viewing
and here is the link for the video (embed looks strange just now)
http://www.youtube.com/watch?v=5OqG2LesnSo
Please add some explanations, I am working in a similar mount, the matter is very interesting for me.
I am not planning anything else. It simply takes up too much time and I need to get back to other stuff (like work!) and earning money.
You could put in a request for a new instructable about equatorial mount on the forums.
Anybody with a telescope probably knows more about it than me. It would be great to see them contribute.
Brian
I know the equatorial mount, I use it in my solar cooker. It is the best mounting for a solar based device.
My "parabola" is a mirror arrange, Scheffler-Fresnel like.
Please let me know if it is helpful
Brian
I also added a transcript to the short video. It doesn't work exactly right but perhaps it helps a bit. It finally has captions! Hurah.
Brian
Thanks for the captions. they help a lot. Now I can understand your proposal. I think it is a little complex. My design uses equatorial mount with a steady grid (it doesn't move anyway) where I put the foods to cook. The image is from an older assembling, but it serves as example.
http://www.youtube.com/watch?v=0-bj0guW0k0 is an attempt to solve a center of gravity problem with parabolic reflectors as the sun path goes up and down with the seasons. But maybe your idea of the counterweight above the reflector dish would work with this also. So In my video, the dish would still be attached at the sides with the seasonal adjustment made in the same way. But a counterweight would be attached above (like yours) to bring the center of gravity of the dish onto the focus. Once it is on the focus, you mount your dish and you never have to adjust the mirrors (or anything else) again! The seasonal movement and daily movement will still have to be done by rotating as directed of course.
Or is that totally wrong?
Brian
My mirrors arrange is very heavy, the glass only, it weight 6 Kg. The support plat must be consequently strong, and consequently heavy... My counterweigth is a little light, but I don't want to do a VLM (very large machine) ;)
We will just have to wait and see if anyone is interested, I guess.
Brian
The pot is exactly on the axis, so it will work for the whole day without readjustment, only to seek (refocus with the crank) the sun each 10-15 minutes.
Look, the thick tilted bar under the pot is the axis. My design is 90 degrees of yours. But it functions too, I cooked in winter meat, sausages, spaghetti, compote, etc. Successfully.
Something between my solar accumulating barbecue idea (but done much better that what I did) and the Scheffler designs.
and you have a much better counterweight than I had too.
(I guess the thing on the right up high is a counterweight?)
Mirrors give a lot more certainty than home made dishes.
(You told me that 2 years ago and you are still right today!)
Perhaps you should do an instructable with more pictures.
Thank You
Brian
Y will do an instructable maybe this year. My project is stagnant by many domestic matters.
http://solardesign.ning.com/
or on solarcooking http://solarcooking.wikia.com
where it can get lots of views
I can put it in either site if you email me the photo.
with your name and details.
Brian
Ok, I guess I should do it, (for english speakers too). It will take a while.
Brian
http://www.youtube.com/watch?v=0-bj0guW0k0 which is the latest video about the tracking solar accumulator
To be held May 8th in Toronto, Canada
