Introduction: Eremote Thymio 2000
A remote controlled thymio robot. Base code used in purple mode with some of our own code added.
Step 1: Program the Remote
Materials:
OneForAll Universal Remote integration with Thymio Robot
How to program a remote to a thymio:
1. Set THYMIO to the pre-programmed PURPLE mode
2. Press and hold the SET button.
3. When the LED light flashes twice, press the buttons 1454.
Step 2: How to Use the Remote
If you can not insert the code or have no use for motion sensors, follow these guidlines. Note: with the code, you can also stop with 5.
4= turn left
6=turn right
2= go forward
8= reverse
When in action, press 8 to cancel actions, but when in reverse, press 2 to cancel actions
When pressing #s twice, action is accelerated.
Can have 2 running at same time (forward, left), or (forward, forward); meaning it just adds to the motor speed (to stop, press opposite of where it is, like (forward, back) or (left, right) or just press center button on robot.
Step 3: Program the Robot
Now connect the Thymio to your computer and insert this code: ( you can use the instructions on the page before or our movie)
<!DOCTYPE aesl-source>
<network>
<!--list of global events-->
<!--list of constants-->
<!--show keywords state-->
<keywords flag="true"/>
<!--node thymio-II-->
<node name="thymio-II">var temp
var rc5_speed_l
var rc5_speed_t
var vmin=-600
var vmax=600
var led_pulse
timer.period[0]=20
sub setmotor
call math.min(rc5_speed_t, rc5_speed_t, vmax)
call math.max(rc5_speed_t, rc5_speed_t, vmin)
call math.min(rc5_speed_l, rc5_speed_l, vmax)
call math.max(rc5_speed_l, rc5_speed_l, vmin)
motor.left.target = rc5_speed_l + rc5_speed_t
motor.right.target = rc5_speed_l - rc5_speed_t
onevent button.left
if button.left==1 then
rc5_speed_t = -200
end
callsub setmotor
onevent button.right
if button.right==1 then
rc5_speed_t = 200
end
callsub setmotor
onevent button.center
if button.center==1 then
rc5_speed_t=0
rc5_speed_l=0
end
callsub setmotor
onevent button.backward
if button.backward==1 then
if rc5_speed_t !=0 then
rc5_speed_t = 0
else
rc5_speed_l = rc5_speed_l-200
end
end
callsub setmotor
onevent button.forward
if button.forward==1 then
rc5_speed_t = 0
else
rc5_speed_l = rc5_speed_l+200
end
end
callsub setmotor
onevent buttons
when button.backward==1 and button.forward==1 do
rc5_speed_l = 0
end
when button.right==1 and button.left==1 do
rc5_speed_t = 0
end
callsub setmotor
onevent timer0
#Body color pulse
led_pulse = led_pulse + 1
if led_pulse > 0 then
call leds.top(led_pulse,0 , led_pulse)
if led_pulse > 40 then
led_pulse = -64
end
else
temp=-led_pulse/2
call leds.top(temp, 0, temp)
end
onevent rc5
if rc5.command !=0 then
if rc5.command == 2 then
if rc5_speed_t!=0 then
rc5_speed_t = 0
else
end
elseif rc5.command == 4 then
rc5_speed_t = -200
elseif rc5.command == 8 then
rc5_speed_t = 0
else
end
elseif rc5.command == 6 then
rc5_speed_t = 200
elseif rc5.command == 5 then
rc5_speed_t = 0
rc5_speed_l = 0
end
rc5.command = 0
end
onevent prox
call sound.system(-1)
call leds.temperature(0,0)
call leds.top(0,0,0)
call leds.circle(0,0,0,0,0,0,0,0)
if prox.horizontal[2] > 3000 and rc5_speed_l > 0 then
rc5_speed_l = 0
end
if prox.horizontal[0] > 1500 and prox.horizontal[6] < 1000 and rc5_speed_l > 0 then rc5_speed_t = 300
end
if prox.horizontal[6] > 1500 and prox.horizontal[0] < 1000 and rc5_speed_l > 0 then rc5_speed_t = -300
end</node>
</network>
