Ergonomic work station
If you work at a computer you are in danger of repitive strain injury (RSI). Setting up an ergonomic work station can be crucial to your health and happiness.
Check out my other various ergonomic Instructables:
Stand Up Desk, Standing Desk, How to make a vertical, ergonomic (tie-fighter) keyboard, and Create an Ergonomic Standing Desk and Office on the Go.
Step 1Research, experiment, and listen
RSI is typically the result of a mismatch between what your body evolved to do, and what you are actually doing. In their natural state, humans collect fruits and vegetables, hunt game, carry their young, and explore their surroundings. To succeed in the modern world, humans sit still, focus on a tiny area for long periods of time, slam their fingers repeatedly against artificial surfaces, and ignore their surroundings. Unfortunately, building up the resources and free time to explore our surroundings often means hammering out that last bit of code, or finishing up a document with just another thousand mouse clicks.
This project documents what I have done to control my RSI. Controlling yours will be different and you will need to research, experiment, and listen to your body.
Resources I found useful: "Repetitive Strain Injury : A Computer User's Guide" by Emil Pascarelli and Deborah Quilter. Both authors have new books that are probably also good. Hand University has great pictures of the wrist to help you understand what might be inflamed. The ATIC Lab at MIT has resources and also allows students to borrow various keyboards and pointing devices to try them out, which is truly invaluable.
For me, the hardest part of this process was listening to my body. The pain usually does not come immediately, so it is often very difficult to determine what activity caused it. What I found is that pain is not discrete. There are levels of feeling before true pain that can signal distress or damage. Generally, these manifest themselves as "being aware" of some part of your body. For example, after typing on a small or badly positioned keyboard I will become aware of my wrists; I try to recognize these signals and take a break or stop to prevent progressing into pain.
52 comments
1-40 of 52next »
Dec 19, 2005. 1:22 PMdetchells says:
I winced when I saw the beachball chair! My urologist tells me that we computer guys have taken over the position of Kings of Prostatitis from the long-haul truckers. - Constant pressure (or worse, pressure and vibration) can lead to an inflamed prostate, which is no fun at all. For anyone prone to prostatitis, even sitting on a firm, flat chair seat can greatly exascerbate the problem. I use an ungainly red rubber donut that looks goofy but helps greatly. A convex surface like that shown would be exactly the *wrong* thing to do for someone like me (and probably a lot of other (male) geek types who spend too many hours/day sitting in front of screen).
Aug 9, 2011. 3:49 AMdetchells says:
(Sorry for *vastly* delayed reply)
Yes, a donut of some sort on top would be the ticket. Inflatable donut-pillows are widely available in drugstores here in the US.
Oct 22, 2006. 6:31 PMzachninme says:
I hope you mean a donut cushion, not the pastry! That would get messy, especally a jelly donut... But on the realistic side, you should do one on the top, and one on the bottom. This way you stay somewhat still. If you want to move, rotate the ball 90 degrees.
Jan 9, 2006. 11:57 AM42rocky says:
Are you sure that the surface is convex. In my experience the balls are stretchy and bouncy and conform to pressure, so that the surface is not convex when pressure is being applied. Keeping the ball underinflated would accentuate this property.
Aug 1, 2006. 1:31 AMjaime9999 says:
try this: train yourself to mouse with your left hand. Why? because the qwerty keyboard is heavily right-hand centric, especially if you do a lot of editing with the cursor or insert/delete/home/pageup/down keypad or do a lot of number entry with the numeric keypad. By training your left hand to mouse, you will more evenly distribute workload across both hands. I did this in 1992 when first introduced to hi-res mouse pointing, and never had wrist problems. Also, learn your keyboard shortcuts for certain tasks, and use them instead of the mouse as much as possible. For example, use Alt-F4 to close windows rather than the hard-to-hit close button, Ctrl-R to Reply to an email in Mozilla/Thunderbird, and Ctrl-Enter to send a composed email in Mozilla/Thunderbird. The above trick is a boon when you occasionally have to use bad touchpads or push-sticks on laptops.
Jun 4, 2011. 2:05 PMfinton says:
I concur jaime. Becoming ambidextrous (at least with computer mice) has solved my RSI problems. See http://www.instructables.com/id/Become-an-ambidextrous-computer-mouse-user/ for pics of this. It doesn't take long to learn and becomes second nature, like any set of muscle movements (once you learn to ride a bike you never forget, and when was the last time you gave any thought to the muscle movements required to drive a car?).
Oct 22, 2006. 6:34 PMzachninme says:
Why not train yourself on a Left-hand Dvorak Keyboard? It allows you to type with only one hand. This way you can easily multitask, and reduce stress on your right hand. They say you can type just as fast with it as with a QWERTY layout. I know that this would then cause left-hand strain, but if you are used to the right hand, it is a good change :-P
Jan 9, 2006. 12:50 PM42rocky says:
I have problems with trackballs that require thumb use as I feel any extension of the thumb in my wrist. However, I have not tried the newer trackballs which have repositioned the ball for your fingers. Does your 3m mouse require much movement of the thumb? Also knowing the function keys for your operating system can reduce the amount of time spent mousing.
Jun 4, 2011. 4:09 AMfinton says:
Have you tried this, 42rocky?:
I agree with you about knowing the function keys, though: saves a lot of time scrolling through documents, websites and spreadsheets!
Dec 6, 2009. 8:37 AMdjsc says:
looked this up after 10 weeks of almost constant RSI, realised its time to get serious. I have nowhere to try out the ergonomic mice so I think I will get a cheap gaming joystick online and use that- suggestions anyone? My doctor rtold me its an overuse injury and all you can really do is:
stop.
take ibuprofen
get an over the counter wrist support.
he said the wrist support mostly works by warming the area- I don't get the cooling thing but I have heard people say that alternating ice packs and 'deep heat' is good for sore joints.
Dec 6, 2009. 8:39 AMdjsc says:
one advantage here being that cheap joysticks seem to be ambidextrous-not moulded to either hand so you can change frequently.
Dec 18, 2009. 10:10 AMdjsc says:
joystick as mouse replacement= bad idea. tried it, doesn't work.
This does give me an idea for a project though; the posture of the joystick is great, and much potential for incorporating loads of buttons. we need better input devices.
Oct 20, 2007. 9:43 AMelectronicfreak22 says:
This is really cool. Lol just don't let Jim pop it with his scissors.
Aug 16, 2009. 7:17 PMWakingCityOfEvil says:
lol.
Feb 11, 2008. 2:12 PMbumpus says:
hahaha, i love teh office
Feb 11, 2008. 12:26 PMdarth2o says:
Yeah, that was so funny.
Aug 5, 2009. 4:39 PMdpdonohue says:
wtf lol i just slouch in my chair 1 leg on the desk one on the old CRT monitor that displays the CCTV images :L
Apr 2, 2009. 9:41 PMclatterclatterbenz says:
i appreciate the work you put into this, i really do. but unless you have had some sort of injury, i would venture a guess that your muscles/tendons are not being worked enough. i used to get cramping in my wrists after using my laptop for a while. now i go bouldering every week. my wrists don't hurt anymore and chicks dig the popeye forearms ;)
Mar 19, 2009. 9:49 PM2 stroke says:
what is that wood thing under your laptop
Jul 8, 2008. 4:16 PMYerboogieman says:
nice, im going to work!
Jun 1, 2008. 6:26 PMLowEnergy says:
Very nice. I particularly like the emphasis on listening to your body. I had serious trouble for a while, but figured out what the problems were and found what works for me, and it's almost never a problem anymore. What works for me is quite different from the standard advice. So I think the most important advice anyone can give is to really listen to your body.
May 30, 2008. 12:08 PMg12345389 says:
nice chair
Apr 22, 2008. 7:41 PMmr mod says:
lol this guy does everything if i had made all of his contraptions, i would be the most productive person there is, but....i didn't make one thing of his so...u know
Jan 28, 2008. 1:30 AMjohnny2474u says:
Great Instructable !! Thank you & I will spread the word
Nov 26, 2007. 10:36 AMInstructorGadget says:
I bet this is good for your posture too since it will force you to sit straight....I need this. lol.
Sep 24, 2007. 9:18 AMmetrometro says:
Vitimin I (ibuprophen) is kind of a crappy painkiller. But it's a GREAT anti-inflammitory. If you're dealing with carpal (inflamation of a tendon), you have to get the inflammation down. Steady low doses of anti-inflammatories are the best weapon you have, along with cold and rest. Don't worry about 'not noticing the pain'. For one, that's also an issue with ice. Second, if you're taking steady doses of drugs, you're going to be aware of the issue, yeah? Inflammation is more like a toggle-switch than a sliding scale. When your tendons are inflamed, any work hurts. When they aren't, you can do whatever, and you're fine. So use every tool you've got.
Aug 28, 2007. 5:24 PMendangeredspecies says:
Neat Instructable with some decent info between the actual content and comments left by various people.
In regards to mice-related issues, I think you may be very interested in this:
Wacom and RSI
and further,
Wacom
I use one of these everyday and simply adore it. The cheapest they get (from Wacom direct is $100, which may be a little pricey for an input device but well worth it in the long run I believe - especially if they really do prevent RSI as well as they claim (which I personally belive they do from experience).
(No affiliation with Wacom by the way, I just think everyone who uses a computer should have one of these =P )
May 26, 2007. 11:29 PMguyfrom7up says:
That picture reminds me of that one episode of the office with Dwight sitting on one of those balls
Nov 18, 2006. 6:30 PMMicromegas says:
A norvegian brand produces a "Vertical Mouse", both left and right handed. Have you tried that one ? is it any good ? I saved your article in favorites, it might come in use.
Nov 21, 2006. 12:59 AMMicromegas says:
Nov 26, 2006. 2:56 PMzachninme says:
I may make an instructable on converting a mouse to "vertical". It shouldn't be that hard to take a optical one. After all, it is already in two halves, the buttons and the sensor. The problem would be casing.
Dec 6, 2009. 8:29 AMdjsc says:
no, the advantage would be the casing- made to measure! somewhere on the web is a guy who made earphones moulded to his inner ear with 2 part epoxy putty, I am thinking thinking similar but for a vertical mouse.
Nov 26, 2006. 11:48 AMzachninme says:
I found that simply tilting my monitors to the most tilting position (It says 15, but I think it is 20 degrees), I bettered my posture greatly. I have bad eyesight, so I tend to lean forward, and this helps for some reason...
Oct 31, 2006. 11:40 AMvinodkp says:
Very good for us computer junkies who spend more time on the computer than with the girl friend.
Jan 9, 2006. 12:33 PM42rocky says:
Your standing station is well positioned. Are you using a joystick? I use a touchpad as I tend to give mice the deathgrip.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
657
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
