3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Escher Print
Escher Print
Make a physical Escher print by cutting different parts of a tessellation in different materials.
Step 1Get image
Get image
Get a digital copy of your favorite tessellation either by scanning a paper copy of searching the web.
I chose reptiles.
14 comments
Sep 28, 2008. 1:24 PMstasterisk says:
How do you get OMAX to cut non-closed polygons?
Feb 22, 2007. 4:26 PMT3h_Muffinator says:
That's incredible! I wish I had a laser cutter now........
Feb 11, 2007. 1:00 AMgowithflo says:
Shut UP! That is awesome. OK I have a thought, if you only cut one, and you had three colors of spray paint you could make some ferocious stencil art by spraying once, rotating, changing color, spray, rotate, change.... am i right? Can you imagine how disorienting it would be to walk on a whole sidewalk covered in this?
Feb 23, 2006. 6:19 PMIIIIIIIII says:
wow! too much cutting needs patience
Jan 28, 2007. 2:21 PMzachninme says:
You use a laser cutter ;-)
Nov 12, 2006. 1:34 AMlazinet says:
Cool design really, funny & gorgeous, must be a great decor at home, but seems a bit fragile.
Oct 22, 2006. 3:09 AMZombie Stomp says:
This is a great idea. What kind of class are you taking, or where do you work that allows you acess to such equipment? And what kind of equipment is it? I saw you used an "abrasive jet" to cut the aluminum. I am in a wlding class that has a plasma cutter, but nowhere near anything with that kind of precision. Care to lead me to some more info on the tools?
Sep 10, 2006. 3:59 PMSk8rDuck says:
dude, That is so awesome!
Jun 10, 2006. 11:56 AMChristophera says:
it does require CAM does it?
Nov 26, 2005. 7:40 PMthoughtstorms says:
Very nice. I have an original tessellation i've been wanting to do this with - but so far no luck. Mine has the same form in six different colours, and i'd love to use wood, copper, marble, glass, alabaster and ceramic. I will keep at it - and this was helpful material!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
701
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
