Make an Eskimo Style Kayak Paddle from 2x4 Scrap Wood in 1.5 hours
This traditional pattern of paddle is a joy to use. The blades aren't feathered (rotated relative to each other) so they're easy for beginners to use.
I just made two of these in less than 3 hours according to the timestamps on the photos.
I wasn't rushing, that's just how long it took.
Read Nativewater's Eskimo paddle pages to learn theory and refinements of this type of paddle.
Paddle Dimensions:
The paddle is 7 to 8 feet overall.
The blades are 3.5" wide at the tips and 2.5" wide where they meet the handle.
The handle portion in the middle is 24-27" long, 1.2" wide, and 1.5" thick.
Size the handle portion to suit yourself.
Tools I used:
safety glasses
dust mask (very important. You'll be making storm clouds of dust)
table saw or bandsaw or jig saw or hand saw for cutting the outline
hand saw (Japanese pull saw)
electric planer
angle grinder
with Porter Cable 24 grit carbide disk ($7!)
with 50 and 80 grit resin bond sanding disks
sandpaper
C clamp
ruler and magic marker
  More paddle and oar making projects:
Here's the quickest way I know to make a paddle.
If it's oars you need, here's how to make oars from 2x4s.
Make a steering oar for a Marshall Islands Racing canoe.
Step 1Get Wood
Get Wood
I brought a paddle with me to help see where any knots would be if I used a certain chunk of lumber to make a paddle.
Dig around in the guts of a demolished house or barn til you find a softwood 2x4 about 8 feet long Look for straight grain and no knots where the middle handle portion.
Knots in the blade area are okay, imagine whether the knots will make the paddle too weak or not.
Usually it's easier to find clear wood on a bigger plank such as a 2x6, 2x12, etc. They came from a bigger tree and you've got more leeway to dodge knots.
New cheap 2x4s tend to be the core slice from a log and have lots of knots from the baby tree.
I found a good old 2x8 with knots in all the places that wouldn't be paddles. It's weathered and severely cracked, but that doesn't bother me. The blades are carved down past the bottom of the cracks. I'll fill any cracks in the handle portion.
14 comments
Apr 25, 2010. 2:01 PMseabananers says:
you should change that to inuit because eskimo and indian are kind offensive to some people
Jun 25, 2011. 4:12 AMcorey_caffeine says:
inuit is a different tribe
Jul 2, 2011. 10:46 AMseabananers says:
really?
Jan 2, 2012. 9:38 PMblack hole says:
No, Inuit and Eskimo are one and the same. . Inuitt means more or less "The People". Eskimo is an Algonquin word meaning "Eater of Flesh"
Dec 23, 2011. 1:50 AMquaybusinessoffices says:
Nice !! Will it take really one and half hours !!
Jun 23, 2011. 5:14 PMrawly old says:
Tim,
I made my paddle even simpler, but it still works quite well.
I'm tall and broad shouldered so i wanted a 90" paddle. I
cut 2 28" blades from a 5" wide strip of scrap 3/8" plywood.
I had an old seasoned 75" doug fir 2x2 which i back cut 21", 3/8"
deep. on the side opposite the back cuts i tapered the ends to 3/4".
i drew a midline thru the blades and handle. With a couple squeezes
of construction glue, I snugged the blades into the back cuts and
aligned the mid lines and zapped in 3 1 1/4" drywall screws. With
a rasp I rounded off the 2x2 at my grip locations, slopped on some
spar varnish, and was good to go.
(Note: blades are 5" wide at the end tapering to 2 1/2" where they butt
to the back cut, corners rounded off. This paddle is lighter, and far
less work to use than my $125 Mohawk whitewater paddle.)
Aug 3, 2010. 10:56 PMjeffconnelly says:
what about using a 2x6 for a wider paddle blade? and, is the preferred style of paddling any different from using a wide blade? (e.g. a more vertical paddle for deeper strokes)
Mar 25, 2010. 6:48 PMDaveFlorida says:
These are fun to build, and fantastic to paddle with, though I am not sure of the "beginner" comment.  I modify mine (have built several) by using a 2x6
stock of wood, Have used solid ash, but prefer a laminate of cedar and pine,
with a core 'backbone' of doug fir.  Make sure to use marine epoxy to glue the laminates, I buy all my materials at Home Depot.  Also, I finish mine with fine sanding, and an acrylic or poly coat. If you are addicted to rolling, these are fantastic to work with.
Thanks for the comments.
Dave, in Florida
Oct 31, 2009. 1:09 PMkill-a-watt says:
I've never seen the carbide disc before. Is it like really long lasting, coarse grit sanding disk, except with a metal backing?  Cool.
Nov 29, 2009. 6:06 AMkill-a-watt says:
one description says: "Use belt cleaner to clean or soak overnight and reuse". So for really big jobs you may need several, just like a pro might have several batteries for their cordless tools.
looks like it comes in 48, 36, and 24 grit.
http://www.drillspot.com/tag/tungsten-carbide-disc/
Nov 1, 2009. 5:27 AMhoosier45678 says:
How is freehanding with the table saw preferable to the bandsaw?
Oct 31, 2009. 1:16 PMTool Using Animal says:
Very nice, i made one once using nothing but a block plane, three problems with that, it took forever, my wife came home to a living room full of shavings and freaked, and I planed the tip of my finger off.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1186
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
