I just made two of these in less than 3 hours according to the timestamps on the photos.
I wasn't rushing, that's just how long it took.
Read Nativewater's Eskimo paddle pages to learn theory and refinements of this type of paddle.
Paddle Dimensions:
The paddle is 7 to 8 feet overall.
The blades are 3.5" wide at the tips and 2.5" wide where they meet the handle.
The handle portion in the middle is 24-27" long, 1.2" wide, and 1.5" thick.
Size the handle portion to suit yourself.
Tools I used:
safety glasses
dust mask (very important. You'll be making storm clouds of dust)
table saw or bandsaw or jig saw or hand saw for cutting the outline
hand saw (Japanese pull saw)
electric planer
angle grinder
with Porter Cable 24 grit carbide disk ($7!)
with 50 and 80 grit resin bond sanding disks
sandpaper
C clamp
ruler and magic marker
More paddle and oar making projects:
Here's the quickest way I know to make a paddle.
If it's oars you need, here's how to make oars from 2x4s.
Make a steering oar for a Marshall Islands Racing canoe.
Remove these ads by
Signing UpStep 1Get Wood
Dig around in the guts of a demolished house or barn til you find a softwood 2x4 about 8 feet long Look for straight grain and no knots where the middle handle portion.
Knots in the blade area are okay, imagine whether the knots will make the paddle too weak or not.
Usually it's easier to find clear wood on a bigger plank such as a 2x6, 2x12, etc. They came from a bigger tree and you've got more leeway to dodge knots.
New cheap 2x4s tend to be the core slice from a log and have lots of knots from the baby tree.
I found a good old 2x8 with knots in all the places that wouldn't be paddles. It's weathered and severely cracked, but that doesn't bother me. The blades are carved down past the bottom of the cracks. I'll fill any cracks in the handle portion.
I made my paddle even simpler, but it still works quite well.
I'm tall and broad shouldered so i wanted a 90" paddle. I
cut 2 28" blades from a 5" wide strip of scrap 3/8" plywood.
I had an old seasoned 75" doug fir 2x2 which i back cut 21", 3/8"
deep. on the side opposite the back cuts i tapered the ends to 3/4".
i drew a midline thru the blades and handle. With a couple squeezes
of construction glue, I snugged the blades into the back cuts and
aligned the mid lines and zapped in 3 1 1/4" drywall screws. With
a rasp I rounded off the 2x2 at my grip locations, slopped on some
spar varnish, and was good to go.
(Note: blades are 5" wide at the end tapering to 2 1/2" where they butt
to the back cut, corners rounded off. This paddle is lighter, and far
less work to use than my $125 Mohawk whitewater paddle.)
stock of wood, Have used solid ash, but prefer a laminate of cedar and pine,
with a core 'backbone' of doug fir. Make sure to use marine epoxy to glue the laminates, I buy all my materials at Home Depot. Also, I finish mine with fine sanding, and an acrylic or poly coat. If you are addicted to rolling, these are fantastic to work with.
Thanks for the comments.
Dave, in Florida
looks like it comes in 48, 36, and 24 grit.
http://www.drillspot.com/tag/tungsten-carbide-disc/
My bandsaws have fine tooth metal cutting blades in them at the moment, and I was too lazy to change them. They cut wood slowly and the damaged blades make the cut a little wiggly.
