3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Etched Acrylic Postcard #2: The Spiral Connection
This is my second attempt at sending out an acrylic postcard. I learned a few things the last time with the split-etched which surprised me by successfully reaching its destination. Instead of making a card that is cruel and tough to read I wanted to make one that could reveal itself all at once by closing one eye and getting the right angle and distance from the card.
So what did I learn?
Expand the bottom layer
In the original card, I cut up the image and put half on top and half on the bottom. I didn't take into account of how the thickness of the acrylic would make it impossible to see the images line up. It still looked cool so I mailed it, but I wanted a more complete look to it.
Use a visual cue
With 24 square inches of space to use, I was only using a small fraction of them. With an expanded bottom layer it would help to have a visual cue to let the user know where to hold the card to see the images line up. I started with circles, but spirals look cooler.
Use complementary images
With the visual cues of the spiral, I needed to make sure that I had two complementary images. This means that two shapes had to come together to form a solid mass.
So with all that in mind and the results right below this, this Instructable is meant to show how the layers were created in Illustrator. Several other imaging programs can be used as well. I am just using what I'm used to.
Materials and Tools
Scrap 3/8" acrylic from Tap Plastics.
Laser cutting and etching with Squid Labs' Epilog Mini 24.
Vector illustration with Adobe Illustrator CS.
Step 1Make a Spiral
Make a Spiral
Easy enough. Just click on the spiral icon, the one hiding behind the line icon, and click on the screen to bring up this window.
I punched in:
Radius = 4 in.
Decay = 90%
Segments = 100
20 comments
Mar 4, 2009. 12:36 PMcornec says:
Doesn't it smell really bad??
Aug 14, 2009. 10:09 PMcowe says:
depends on the type of acrylic - extruded acrylic (which is mostly used for its ability to get a smoother, more flame-finished laser cut) smells like DEATH, imho. do not want. ...while cast acrylic (which, though more expensive, is always my preference, as you can get a more refined/even looking raster engraving, and still a decent looking cut) has a sweet smell when lasered, similar to the candy-like bouquet wafting through a nail salon. always good to have a nice filtration setup though, so you're not stuck in an acrylic fume-cloud all day.
Jul 27, 2009. 7:36 AMBooyaka3 says:
Awesome Instructable, now all I need is to convince my dad I need a Laser Cutter well Good Luck to me!!
Mar 8, 2009. 8:10 AMXenel says:
Step 11, Optical Illusion Alert!
Mar 4, 2009. 12:38 PMcornec says:
I understand etching is much slower then the cutting setting. And how long does it take to etch per block?
Aug 11, 2007. 3:55 PMidontcare says:
you could also combine it with the IKEA Window Postcard
Apr 26, 2007. 8:39 AMTofu says:
I'm just curious as to how the piece handled the shipping rigors. Did it get chipped up, scratched, cracked? It looks great in the photos but I'd be curious to see how it looked when it arrived at the destination. Finally, you should start a cottage biz making desk placards like this. I would sooooooo pay for one of these.
Jan 16, 2007. 8:05 PMrobonut625 says:
Very nice! I really like that clean look!
Jan 16, 2007. 4:57 PMnah says:
That's great. It also makes me wonder how it would look if it were colored. Maybe make the top spiral red and the bottom white, or whatever colors you like. I'm not really sure how this could be done, because etching wouldn't work. Does anyone know of a translucent dye that might do the job?
Jan 15, 2007. 6:50 PML.L.Moorloch says:
Hey, it's very cool. But I'm reminded of the old Steve Martin joke: "How you can make a million dollars and never pay taxes! First, get a million dollars...."
What do you have to do to laser cut acyrlic? And how do you etch it? If you want to be really helpful, you gotta turn loose of more information. Otherwise, you're just showing off. (A cool thing to show off, mind you, but still just showing off.)
Moorloch
Jan 16, 2007. 1:52 AMpinski1 says:
Etching acrylic, can you not just buy some etching spray? In the UK it's sold in DIY stores, make a template out of card, after all most modern printers are accurate to 5760x1440dpi or more. Then use that as a mask? Just because you don't have all of the fancy kit, doesn't mean you can't do it a slightly more labour intensive manner. Not to say that I wouldn't mind a free Laser cutter.
Jan 15, 2007. 10:35 PMursonate says:
So how did you stick the postage on?
Jan 15, 2007. 2:18 PMjoedog86 says:
That is incredible. I simply don't have to words to express what an awesome project this is. You have some lucky friends.
Jan 15, 2007. 3:31 PMsteffrock says:
i'm new here, so i have a basic question...the illustrator stuff i get, but buying the acrylic piece(where?) and laser cutting(how, with what?) is the stuff I don't get. plus, was there limitations or issues with posting it as a "postcard?" thanks, newb ps. i'll try to look at your previous job and maybe that'll answer me questionns.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1413
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
