3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Etched Minty Valentines Candy Box
Or.. a good demonstration of why throwing a radio into the bathtub will kill you. I'll explain later.
Speaking of killing you, as we are using water and electricity here, please be supper-duper cautious. I can't be held responsible for burned fingers, house fires, dead cats or any combination thereof. Please use some common sense!
This is a decent project that should cost you little or no money, depending on what you have laying around the house. The idea is to use electricity and salt water to etch an image into the top of an altoids tin. The same process can be used to actually cut the image all the way through if allowed to go long enough. I'll explain the principles behind this as we go along.
First things first, Project materials and cost:
1 Altoids can, or similar metal canister - $0 (I'm using garbage here...)
1 spare DC power supply brick. 5v or greater. Preferably a decent amperage. I use a 12v 1A supply. it really seems to make no difference beyond how long the etch will take - $0
Old PC case fan, light bulb.. something that will run on the current from the power supply. This is used to limit the amount of current being transmitted, as you don't want to burn out the power supply. - 0$
1 PLASTIC bowl or pan. Never NEVER use a metal pan of any kind. - 0$
About half a cup of salt. - 0$
A couple of bolts and some heavy copper wire - optional 0$
Plastic packing tape (I use clear.. don't have to I suppose.). Not masking tape. It has to stand up to salt water - 0$ I steal mine from my day job.
Sandpaper, or green scrubby. -0$ I used the scrubby from my kitchen sink. Don't tell the girlfriend.
Razor blade or knife. I highly recommend an Exact-o or similar, although I did this with a straight "utility" style blade.
Step 1Prep the minty tin
Prep the minty tin
For the tin to etch properly, the top of the tin will need to be cleaned to bare metal. This can be done with a fine grade of sandpaper, or a green scrubby. I tend to go with a little of both.
Run the tin under hot water and sand lightly until most of the paint is gone. then clean it up with the scrubby. any areas where there is paint remaining will not etch properly, so take your time.
When it looks clean, rinse and dry it off thoroughly. At this point, try not to touch the surface any more than you have to . The oils from your skin could affect or block the etching.
189 comments
1-40 of 189next »
Jan 29, 2007. 4:08 PMzus says:
What metals can you do this on ? I'm guessing pretty much everything except steel ? any kind of soft metal ?
Apr 16, 2012. 9:48 PMpetmjohn says:
It works on steel and stainless steel. Take a look at this instructable:
http://www.instructables.com/id/How-To-Electro-Etch-a-Solid-Metal-Plaque
Nov 2, 2008. 5:26 PMAznPanda says:
Altoids cans work im guessin
Apr 22, 2008. 4:45 PMGonazar says:
I think copper is ideal isn't it? it makes a better oxidizing agent in the electrolytic cell. I just finished my chemistry 12 course, so i'm kinda testing the water in applying it in real world.
Jan 13, 2012. 2:51 PMpdenise says:
Did this with a single 9v battery, and it worked quickly. The battery seemed a bit warm, so next time, I'll try a small load, like a small varistor, or resistor. Great instructable!
Jun 26, 2011. 1:24 PMoub says:
This is the coolest presentation. Thank you so much for this. Thank you mostly for responding to the comments! Every question I had was answered. Oh... and thank you for the sense of humor.
May 10, 2011. 8:16 AMtallpaul100 says:
I've always used the aerosol deodorants to remove marker pen on any wipeable surface. I've never tried with the the actual sharpie brand pens but its worked for all the others I've used. just spray it on and wipe it off! easy as pie. I've even used it to get marker pen of cd's so i can re-label em.
Dec 15, 2008. 2:19 PMHadokendude says:
I had three questions: A) What do you use for a DC power supply? Like a computer power supply, or something different? B) In place of a power supply would a 9-volt battery work? and finally B) Is it imperative that I use a cooking bowl of some sort, or could a plastic disposable bowl work as well?
Jul 11, 2010. 1:48 PMimajem says:
I once made a metal plater for jewelry with a 6/12 battery charger and a kitchen door spring and it worked like a charm....for the DC power.
Jun 20, 2007. 12:29 PMaridese says:
Electrolysis (etching) with table salt is an EXTREMELY DANGEROUS thing to do.
Table salt (sodium chloride) ionizes in water:
NaCl -> (Na+) + (Cl-)
The positive and negative electrodes gather Cl- and Na+ respectively. The positive electrode will make chlorine gas! I am confident you smelled a "pool" like odor when you performed this.
If you don't want to take my word for it, here is a site describing the process in greater detail:
http://chemed.chem.purdue.edu/genchem/topicreview/bp/ch20/faraday.php
In the quantities you are using, the amount of gas produced can be dangerous -- this is the same poison gas used in WWII. An alternative electrolyte you can try for electrolysis is sodium carbonate (washing soda) or sodium bicarbonate (baking soda) heated to 200C to produce sodium carbonate.
For the safety of others, please amend / remove this instructable...
Feb 3, 2010. 10:46 PMmxridercc says:
Hahaha that website shows that the process requires molten NaCl not NaCl(aq). Hardly the same
Jul 30, 2008. 10:18 AMpharoah says:
First, let me point out that Chlorine gas was only used at the beginning of World War ONE, it was replaced with more effective gases such as mustard gas. Second, if you perform this experiment in a well ventilated area you should be fine. I don't think anyone here would be stupid enough to stick their face above the etch bowl and inhale for a few minutes. Just exercise a bit of caution people.
Oct 19, 2007. 7:53 PMthreecheersfornick says:
If table salt ionizes in water... why doesn't the ocean create chlorine gas? Should I stop going to the beach? And, couldn't you just do this outside?
Sep 2, 2008. 9:47 PMfinfan7 says:
has to have electricity.
Sep 11, 2007. 9:22 PMofflogic says:
Aridese- Etching with saltwater is safe, ask someone who knows, like a teacher or art or chemistry. Better still, experience the hazard first hand: etch something. Then you can compare and contrast the sheer hazard vs. running with scissors (the pointy ones, especially) and using household ammonia cleaners (DEADLY GAS!!!!). Chlorine was used in WWI (notably at Ypres, Belgium in April 1915), but was considered more trouble than it was worth. That made it easy to get signatories to the 1925 Geneva protocols that banned the use of "poison gas".
Dec 8, 2009. 10:28 PMAnotherMan says:
What kinds of power supplies would you reccomend? Pc? Car battery?
May 1, 2009. 9:09 AMward2u says:
thank you it is a nice job
Nov 18, 2008. 3:53 PMgnargnar says:
stupid question: where do i get an AC power supply? i have one of those "pick-your-voltage" things and it say AC/DC converter but that doesn't help me much... what's the verdict on 9v battery with a lightbulb in the circuit? also, any examples of the muriatic acid edition? thanks!
Nov 2, 2008. 5:17 PMAznPanda says:
Yeah CAN WE USE CHEAP PLASTIC DISPOSABLE Bowls? Can we use light bulbs instead of fans?? Are you sure this works? or is there a diffrent way to do this? Willa 9 v battery work with copper wiring a completeely sand papered altoids can and a light bulb instead of a fan? Please respond....
Sep 26, 2008. 1:09 PMsiege engines ahoy says:
In addition, can i use one of those cheap disposable plastic bowls/ trying 2 keep my bills to a minimum lol
Sep 25, 2008. 2:21 PMsiege engines ahoy says:
Could you just use a 9v battery for this? assuming you add a shi*load more fans, i assume. . . could i just use a buncha little lights? i want to do this at school with my science teacher . . . great project btw
Aug 15, 2008. 6:05 PMmistermarchman says:
so, this could also work for etching circuit boards, no need for that ferric chloride. hmm. i might just have to try that.
Jun 13, 2008. 3:45 PMtheburn7 says:
dude, if i ever have a mythbusters question, i will ask u
Feb 1, 2007. 9:01 PMBoss_Sauce says:
Thanks for this tutorial! I want to etch everything now...
I did a little experimenting last night-- http://etchtest.blogspot.com
Curious if anybody has figured out a good inky marker that can be used to mask but will clean off with goof off or something...?
May 15, 2008. 4:31 PMLinksep says:
You could try an oil based "Paint Pen" which should clean up nicely with a petrol based solvent (lacquer thinner).
At work I use pure alcohol (they call it E-200, not sure why... 200 proof ethanol?) to remove sharpie marks from aluminum, usually works pretty good but results can vary.
May 4, 2008. 5:07 AMJalakahops says:
I will now reveal to you the greatest sharpie secret. The best way to remove sharpie ink.....is with more sharpie ink. Wait wait let me explain. Write somthing on metal with a sharpie then write over it again and quickly wipe away. Tada, it all wipes off. Inside the pen is the chemical that disolves sharpie ink and it dries quickly. When the solvent dries up all thats left behind is your "permanent" writting.
Jun 13, 2008. 3:41 PMtheburn7 says:
kool ty
Feb 3, 2007. 10:43 AMspinnergrrrl says:
I think you could use liquid frisket (goes on with a brush or a nib.) I use it for masking glass etching, I don't see why it wouldn't work for this.
May 4, 2008. 4:31 AMHOMEPIE64 says:
do another instructable on how to correctly felt the inside
Oct 18, 2007. 5:27 PMBran says:
This is so awesome! This makes me really want to (gasp) etch my Sandisk Sansa View (8gb) when I get it, though I will of course go through many, many test runs. Is there any way that you could etch it without dunking it in the water, as precious electronics don't mix too well with water. Thanks!
Mar 29, 2008. 11:27 AMrecon506 says:
just pop the drive open and pull the circuit board out. then etch, and when you're done dry the board less drive out with a hair-dryer and put the circuit board back.
Oct 19, 2007. 7:51 PMthreecheersfornick says:
Yes, but it's more complicated... you'd have to use a laser or a stronger acid...
Feb 13, 2008. 3:20 AMzetlin says:
anybody got an Instructable on how to etch or make cool images on plastic I have a pp plastic case that i have to use for school any ideas???
Feb 12, 2008. 11:22 PMdizzytired says:
Is this technically electroplating? I dunno if I made a mistake somewhere along the line, but I used a couple chrome vanadium sockets in place of bolts and I seemed to get just a really shiny surface instead of that etched look.
Feb 12, 2008. 9:10 PMEinsteins Circuitry says:
After only 15 minutes of etching, I'm feeling dizzy... Is that normal? ;-) Just kidding. But when I was cleaning the bowl out my hand started to burn a little... Not sure why. Theres not nearly enough chlorine being released, but I believe that Na2O (2 sodium molecules per oxygen molecule) is being created which I think is an acid. (please correct me if I'm wrong) I only have two suggestions: where gloves, and do it in a well ventilated area. PS: Nice Instructable! +1
1-40 of 189next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:photozz
