Step 5POWER ON!
Plug in the power supply. For safety - DO NOT leave the room. Sit there and watch. It should not take that long. And it's cool looking.
You should immediately notice the fan spinning, and bubbles rising from the bolts. If none of this is going on, unplug the power and check all your connections. It could be one of several things.
1. Wires crossed or wired incorrectly. The positive should be on the tin, the negative on the wire/bolts. Make sure nothing is shorting out. If the bubbles are only coming off the tin, you have it wired backwards.
2. Parts are too far apart. Try to make it less than an inch, if you can.
3. Not enough power. You might need a stronger supply.
Once you have bubbles, you will notice the water start to change colors. It can vary depending on the metals you are using. There will eventually be some scum as well. This is all normal. In the pictures, you can see mine going a bit orange.
Let it go for about 5 minutes. You can check every now and then to see how it's working. Times will vary depending on the strength of your power supply. Once it appears to be etched to your satisfaction, unplug the power, and remove the tin. Rinse it well in warm water, and remove the tape. If any adhesive is left behind, just clean it off with GOO GONE or some such solvent.
I would not recommend using the bowl for food after this. The scum left behind should be explanation enough.
7
comments
Add Comment
T3h_Muffinator
says:
Add Comment
