3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Etching brass plates
This is how I etched a brass plate to use as a decorative plate for my laptop lid. I've also used these stuck onto the front of notebooks and sketchbooks as presents for friends. My method draws heavily from this instructable and this website, so I thank the respective authors for their sterling work. There are many, many different ways of doing this, but when I was researching it, there weren't very many thorough tutorials, so I think this may still be useful for some people. But if you're interested, do scour the internet and you'll find a wealth of information about toner transfer and etching - some good, some bad, some just plain puzzling.
The artwork I used is a piece called Tribal Eagle by *xx-trigrhappy-xx and is used with permission.
Step 1What you need (and where you can get it in the UK)
You will need:
Brass plate (I got mine from eBay)
Iron
Computer to prepare artwork
Laser printer and laser OHP acetate (Or do what I did and get a print shop to photocopy it onto acetate for you)
Permanent OHP marker (useful for touching up the mask before etching)
Insulating (PVC) tape (Woolworths/Robert Dyas or hardware stores)
Masking tape (ditto)
Scissors
Non-metal kitchen scourer pad
Kitchen towel
Acetone (optional - but useful. Nail polish remover is mostly acetone and will do nicely)
(Hydrated) ferric chloride crystals ( Maplin)
Fine Wet & Dry paper (Wilkinson or hardware stores)
Some form of sanding block (I just used a scrap bit of wood I had lying around)
Cheap tupperware (You're not going to be able to reuse this for food!)
Rubber gloves (absolutely essential)
Goggles (essential if you're not stupid - don't risk your eyesight doing something like this!)
Dust mask (optional if you're careful and do the painting outdoors - there's not much painting involved)
Spray paint (I used black enamel satin-finish stuff from Wilkinson)
Superglue
48 comments
1-40 of 48next »
Feb 6, 2012. 11:04 AMsiamonsez says:
I can't get the ohp acetate film anywhere near where I live, but a local kinkos-ish place has transparent acetate film they use in a book binding machine and described it as being "thick like card stock," they also said they've never tried printing on it. Anyone know if this would work?
Aug 15, 2011. 7:34 PMkommodore says:
Wow, that's very cool, it etch the hell out of the brass, very deep.
I like it! congrats, i think i will try it.
Mar 14, 2010. 10:15 AMshinojmahe says:
Dear,
nice work,
well any solution to etch on the plastic surface??
waiting
shi
Mar 30, 2010. 8:34 PM-Aj- says:
i dont have easy access to a laser printer and was planning on using the traditional photoresist technique.
Is it worth it? or is it much easier using a laser printer?
Mar 30, 2010. 8:35 PM-Aj- says:
and what a bout quality? as i want to etch a persons portrait
(sorry for the separate reply) :P
Mar 16, 2010. 2:14 AMTommyStone says:
That's a good tip about neutralising the solution and filtering off the copper. Thanks!
Thomas
Jun 22, 2009. 9:33 AMnelfer says:
where do you get a brass plate? I looked in a craft store and didn't have anything.
Jun 22, 2009. 2:11 PMnelfer says:
True. I was wondering if there was any "local" store that might have them at hand, so no need to wait for either a bid to end or just the delivery. I wanted to do something by Wednesday. Today is Monday. Anyway, I guess I'll have to wait. Nice instructable. Very nice.
Jul 3, 2009. 10:17 PMMalleusDei says:
Nelfer, you can by brass plates at lowes or home depot as brass kick plates for doors. Make sure you get the solid brass ones because they also sell brass plated kick plates. about 18 bucks a kick plate but they can be cut into many smaller plates.
May 13, 2009. 4:20 PMkirbyswarpstar says:
pretty cool
Apr 2, 2009. 4:22 PMGato2 says:
One might also consider reversing the image for a different look. Remember if you have writing in your design you have to invert it (mirror image), otherwise it will come out backwards....not fun after all the work.. Cheers
Mar 21, 2009. 8:39 AMvengeance89 says:
nice instructable..but in the toner transfer process it would be safe to use a photo paper than to use acetate..its because it won't melt and won't ruin your design and it can also transfer the image almost perfectly. and i also found a nice etching solution from one of the instructables here..its a combination of hydrogen peroxide(H2O2) and hydrochloric acid(HCI0..the ratio is 2:1, 2 parts of H2O2 and 1 part of HCI,but 2:1 ratio is more effective for me..and the best thing is it is less harmful to the environment and its very quick too..
Mar 21, 2009. 9:01 AMvengeance89 says:
i mean 2:2 ratio.sorry for the typing error.
Feb 3, 2009. 4:14 PMMonk says:
Yay finally an instrucable with some UK stores to buy stuff! excellent instrucable too.
Jun 5, 2008. 2:20 PMpollo del mar says:
I recently used a very similar technique to this to etch a number of brass medallions. However, I wanted to point out that there is a nice complementary Instructable entitled "Stop Using Ferric Chloride" here:
http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
I used the solution detailed in that article to etch over 100 brass medallions. I was able to etch between 10-15 1.25" brass circles with a batch that was 4 cups hydrogen peroxide and 2 cups muriatic acid before I had to mix a new batch. The etching took about 45 minutes to etch to a depth of about 1/32" and was relatively non toxic.
I used a small (5 gallon) plastic fish tank with a light-weight fish tank air pump to do the etching in and keep the solution agitiated.
Jun 6, 2008. 5:32 PMT2Pogi says:
I read in an article that Adding baking soda to the ferric chloride solution will break it down into water, iron, etc. you can pick up or strain the solids out and dispose of the water.
May 27, 2008. 10:33 AMPkranger88 says:
Very nice.
Jun 5, 2008. 6:05 PMPhoghat says:
I just used some dry transfer letters from staples on some .44 mag shell key chains for my friends so they would have the "bullet with their name on it"
May 27, 2008. 10:47 AMagdollison says:
i do agree
Jun 1, 2008. 6:34 PMstonehenge360 says:
couldn't I do this using electrolysis? that seems a lot easier and safer...
May 29, 2008. 3:06 AMawkrin says:
wouldn't it look better without the little board? I mean only the eagle on the laptop: sorry I'm not good at gimp
Jun 1, 2008. 3:08 PMawkrin says:
lol I thought about something like a milling machine to cut it, but you're probably doing this because u don't have a 3d printer sorry..
May 29, 2008. 2:35 PMobamafan says:
That looks AWESOME! Cool job!
May 29, 2008. 2:52 AMjomaro says:
Thats a very good job there.
I have been etching (PCBs) myself with ferric chloride solution.
However I am getting concerned if this is the best choice for chemicals.
Maybe we should take a look the alternatives we have around.
Take a look at this http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
Another solution would be this one
I am not sure what to choose.
Does anyone around have more information about this?
Tks
May 28, 2008. 10:03 AMdarkmuskrat says:
Sweet, a must do for laptops/desktops alike.
May 27, 2008. 4:58 PMblam72 says:
Well done, I might have to try this sometime.
May 27, 2008. 9:19 PMac1D says:
AWESOME!
I have a question, would you be up to sell me one? I would like that have one glued on my EEE =-)
May 27, 2008. 2:41 PMMr. Rig It says:
Very cool, well written. That is something you could sell in the instructables marketplace. Good job!
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:gotang
