3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Etching brass plates
Step 10Painting the plate
Painting the plate
Time to finish it off! Once again, clean and dry is the name of the game here. Get hold of your spray paint and shake it to mix it. Do some test spraying onto old newspaper until you're happy with your technique - remember, light, even passes larger than the object being sprayed, and thin coats. Once you're happy, stick the plate down and paint it! I sprayed mine with three light coats of the paint, letting it dry between each coat. Remember to spray from different angles to ensure that you catch all edges of the etched plate. Ensure the paint is thoroughly dry before continuing - if you're impatient like me, use a hairdryer!
Remove all the tape from the edges and back, and you'll probably find that it's left all sorts of gunk. I'd clean this off carefully at this point by scrubbing gently. Rinse the plate and dry with some kitchen towel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:gotang
