3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Etching brass plates
Step 11Finishing off the plate
Nearly there now. Grab your Wet & Dry paper and wrap it around your sanding block (the block is just there to keep the paper flat) and sand down the surface of the plate. This will expose the brass on any areas that were not etched. Don't worry about the way it scratches the paint surface - it gives it a nice pseudo-aged look.
Once you've cleaned down to the brass all over the unetched areas, add a bit of water to the plate (this makes the Wet & Dry effectively a finer abrasive) and scrub with small circular motions all over the plate to ensure a nice finish. If the paint has been scratched unevenly, then carefully use the paper without the sanding block on the unscratched areas and even it out. When you're happy with the finish, rinse the plate and dry.
Don't forget, if you completely screw up this stage, all is not lost - just clean the plate, respray and try again!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:gotang
