Step 5Toner transfer
iImage Information
Place the brass/acetate sandwich on a heatproof surface (I used some scrap cardboard) and heat up the iron. You want the iron as hot as it will go and no steam! Start with the brass-side up and press down on the back of the metal with the hot iron. This will preheat the brass and help the toner melt. After 20 seconds or so, flip the brass/acetate over without touching the brass, which will by now be extremely hot. Place a piece of scrap paper over the acetate and once again, press down on the brass (this time through the paper and acetate) with the iron, keeping the iron moving. Be careful not to melt the acetate. The actual toner transfer happens very quickly, and I found it needed very little heating with this method - in the order of 5-10 seconds. Take the iron away and immediately peel the acetate back carefully - this must be done while the brass and toner is still hot (which is different to if you're using paper to transfer it). If you let the toner cool first, it will come away with the acetate rather than remaining on the brass.
You'll also find that the adhesive on the masking tape will melt with the heat, so it's easier to peel this off while the brass is hot. Don't burn yourself though!
