Step 4The program
I have to use some tricks to load a web page with more information. The HTML code is stored at the program memory, so, we have enough RAM for the other things. Any questions about the code just ask.
TIP: after download the file, rename it to .pde
Here is the code:
#include <LED.h>
#include <Ethernet.h>
#include <SPI.h>
#include <avr/pgmspace.h>
prog_char string_0[] PROGMEM = "<html><body><h2>Controle de LED pela Internet</h2><font size= 4><form method=GET>";
prog_char string_1[] PROGMEM = "<br><input type=submit name=b1 value=Led1>";
prog_char string_2[] PROGMEM = "<br><input type=submit name=b2 value=Led2>";
prog_char string_3[] PROGMEM = "<br><input type=submit name=b3 value=Led3>";
prog_char string_4[] PROGMEM = "<br><input type=submit name=b4 value=Led4>";
prog_char string_5[] PROGMEM = "<br>Insert your name here:";
prog_char string_6[] PROGMEM = "<input name=msg value=no_name MAXLENGTH=20>";
prog_char string_7[] PROGMEM = "</form></body></html>";
prog_char string_8[] PROGMEM = "Ligada (ON)";
prog_char string_9[] PROGMEM = "Desligada (OFF)";
prog_char string_10[] PROGMEM = "<meta http-equiv=refresh content=30 > "; //for auto refresh
PROGMEM const char *string_table[] = // change "string_table" name to suit
string_0,
string_1,
string_2,
string_3,
string_4,
string_5,
string_6,
string_7,
string_8,
string_9,
string_10
char buffer[85]; // make sure this is large enough for the largest string it must hold
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 134 };
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
String inString = String(35);
Server server(8246);
LED led1 = LED(7);
LED led2 = LED(6);
LED led3 = LED(5);
LED led4 = LED(4);
String msg="";
int tam=0;
int st1=9,st2=9,st3=9,st4=9;
void setup()
Serial.begin(9600);
Ethernet.begin(mac, ip,gateway,subnet);
server.begin();
Serial.println("Serial READY");
Serial.println("Ethernet READY");
Serial.println("Server READY");
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,INPUT);
pinMode(9,INPUT);
void loop()
Client client = server.available();
int led=0;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (inString.length() < 35) {
inString.concat(c);
if (c == '\n' && current_line_is_blank) {
if(inString.indexOf("b1")>0){
led1.toggle();
if(led1.getState()) st1=8;
else st1=9;
led=1;
if(inString.indexOf("b2")>0){
led2.toggle();
if(led2.getState()) st2=8;
else st2=9;
led=2;
if(inString.indexOf("b3")>0){
led3.toggle();
if(led3.getState()) st3=8;
else st3=9;
led=3;
if(inString.indexOf("b4")>0){
led4.toggle();
if(led4.getState()) st4=8;
else st4=9;
led=4;
if(inString.indexOf("msg")>0){
char charBuf1[50];
char charBuf2[50];
strcpy(msg,(char*)inString.substring(inString.indexOf("g")+2,inString.indexOf(" H")));
//Serial.print("msg: ");
Serial.println(msg);
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[0]))); // Necessary casts and dereferencing, just copy.
client.println( buffer );
for (int i = 1; i < 8; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
switch(i){
case 1: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st1]))); client.println( buffer ); break;
case 2: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st2]))); client.println( buffer ); break;
case 3: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st3]))); client.println( buffer ); break;
case 4: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st4]))); client.println( buffer ); break;
delay(30);
if(digitalRead(8)==HIGH){
client.println("<br>Botao 1, ON");
}else{
client.println("<br>Botao 1, OFF");
if(digitalRead(9)==HIGH){
client.println("<br>Botao 2, ON");
}else{
client.println("<br>Botao 2, OFF");
//strcpy_P(buffer, (char*)pgm_read_word(&(string_table[10]))); client.println( buffer );
break;
if (c == '\n') {
// we're starting a new line
} else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
// give the web browser time to receive the data
delay(1);
inString = "";
client.stop();
WebServer_IO.pde5 KB| « Previous Step | Download PDFView All Steps | Next Step » |
sketch_may29a.cpp: In function 'void loop()':
sketch_may29a:84: error: 'class String' has no member named 'append'
sketch_may29a:84: error: expected `;' before '{' token
sketch_may29a:89: error: 'class String' has no member named 'contains'
sketch_may29a:97: error: 'class String' has no member named 'contains'
sketch_may29a:105: error: 'class String' has no member named 'contains'
sketch_may29a:113: error: 'class String' has no member named 'contains'
sketch_may29a:122: error: 'class String' has no member named 'contains'
sketch_may29a:124: error: cannot convert 'String' to 'char*' for argument '1' to 'char* strcpy(char*, const char*)'
sketch_may29a:152: error: expected `}' at end of input
and i have WStrings and led libraries installed
