Introduction: European 4-in-1 Maille (chainmail) Speedweaving
Picture of European 4-in-1 Maille (chainmail) Speedweaving
First of all: maille, mail, chainmail... their all different words for the same thing. I like to use the word maille, but I'm sure some like the other words better.
Maille is a form of armour. It was invented by the Celts and it became very popular in the middle ages, where it was used as 'standard' armour for allmost all soldiers, because it's flexible and prevents cuts from swords, knives etc. Nowadays maille is made for other re-enactments, as 'alternative' clothing, or just for fun like I do.
Back in the days maille was made out of mild steel rings which were riveted. Which means: a lot of work. Today most of the maille is made out of steel wire. And it's not riveted anymore. It's called "butted".
The most common weave is without a doubt "European 4-in-1" (or E 4-1). This is the way the rings were linked in Europe in the middle ages. I'll come back later on the 4-in-1 thing.
I'm Belgian and I live in Brugge (Bruges). But when I was a child, I visited the "Gravensteen" (that's a castle castle) in Gent. There, someone was making maille at the time. I found it very fascinating and the thought of making some my own never leaved my mind really. Some time ago I started making my own maille. Currently I'm making a coif (have a look on Google Images if you don't know what a coif is).
The technique I use is called "speedweaving" because it's one of the fastest ways to make maille. What I will describe is not the only way to speedweave, but this is the one I use, and which works great for me. I did not invent this technique. I'm just sharing it with the world...
Step 1: Making the Rings
Picture of Making the Rings
Let's start making rings.
I used galvanised steel wire. For two reasons: it's easily obtainable and it's cheap. My wire is 1,5 mm thick.
Making rings starts with transforming your wire into coils. And than cutting the coils with a mini bolt-cutter. I won't describe the whole coil-making process but I'll include some pictures of the way I do it. Perhaps I will come back to writing this piece out one day.
My coils have an inner diameter (ID) of 6 mm, but because of a thing called "springback" the rings have a real inner diameter (RID) of 6,4 mm). My rings have an aspect ratio (AR) of 4,3. This is the ratio of RID and the wire size.
Step 2: Opening and Closing Rings
Picture of Opening and Closing Rings
The first thing you have to learn is how to open and close the rings. This is usually done with pliers. I think the pictures are quite clear.
Step 3: Starting the First Row
Picture of Starting the First Row
Well, let's start connecting the first rings. The first 5 rings show clearly how "European 4-in-1" got it's name. 1 ring is always connected by 4 other rings.
Step 4: Continue the First Row
Picture of Continue the First Row
The pictures show how to connect more rings to your first row.
Step 5: The Second Row
Picture of The Second Row
You have a first row. Well, let's start a second one.
Step 6: Make Something
Picture of Make Something
Once you can don this, you can make a lot of things. The only thing you will also need are contractions and exansions. But thats for an other time...
Or try making some really rocking Byzantine chain!
Here's a picture of the finnished coif and me... It took nearly 50 hours te make this one (making the rings and going to the hardware store to buy wire included)
WillS127 (author)2016-09-24
I use 16 Ga wire, mild steel used for either baling hay or for wood stove pipes. Comes in 5 lb rolls, stores well and can be slipped onto a roller beneath a ring-rolling jig so you can snip off what you what and roll as many springs as you can handle. Fairly cheap, although somewhat messy. I use "airplane shears" M-6 to snip the springs into rings and simply butt join them, the M-6 is a good tool, although at my age I brace it against my leg so it isn't all hand muscle. I've made a few pieces: coifs with and without mantles, shirts with 6-1 bodies and 4-1 arms and straight old 4-1 shirts. If you toss in Oriental mail you have a great palette of texture and flow to work with.
DavidH448 (author)2016-03-29
Buying your wire at the hardware store is too expensive. Like $18 - $25 for 200 feet. Go to Tractor Supply Company and you can buy 14 gauge electric fence wire for $50 for a half mile.
CubeKnight (author)DavidH4482016-04-04
Go to home depot or lowes and they have 200 ft 16 gauge gal. steel wire for $6.27.
MichaelC600 (author)CubeKnight2016-06-11
This is bad advice, if you want your chainmail to discolor, stain your skin, or if you do weld your jump rings give off toxic fumes. Just order stainless steel wire off of amazon.
jdoherty6 (author)2015-05-12
I made this using your techniques
MrMxylptlyk (author)jdoherty62016-03-12
wow! This could make a great bracer!!
DerekM33 (author)2016-01-07
it may be just because im starting out but for some reason i cant get it to layout nearly as neat especially on the second row it just looks like a jumbled mess i may also be impatient
metroflamer made it! (author)2015-03-28
16 gauge gal. wire
george17 (author)2015-03-26
instead of spinning jig you used to make the loops you could put them on a drill and do that to make a ton realy fast
andrew.mcdonald86 (author)2015-03-14
I found, on the second row, it was easier to attach 2-1 to the first row then weave 1 open through 3 on the piece and put 1 closed on it.
InspectorD (author)2007-06-23
Man, You have too much time on your hands. It seems that it would take weeks to make anything of any size that would be useful.
travis.bout (author)InspectorD2015-03-02
mate this is a good way to pass time remember blacksmith did this as old women knitting
scalarcharge (author)InspectorD2009-07-12
try months. and where do you think (aside from shark attacks) that chain mail would be useful? it's just cool
Grey_Wolfe (author)scalarcharge2014-12-08
In Renn Faire reenactments, they often use live steel. In such case, real armor is very useful.
Doesn't matter how careful you are, when someone's swinging a real sword, it's a good idea to have a bit of protection in the way.
Actually, maille is much better suited to fending off bladed sweeping attacks (although a form of it is used for crazy people wishing to dive with sharks).
Austringer (author)InspectorD2007-06-24
My trick during college was to keep a handful of rings and my pliers in my backpack. There are about 20 times a day when I found myself having just enough time to put a handful of rings together. When the piece got too big to haul around I thew it in my closet. When I had a pile of them, I put them together into a shirt.
RFilyaw (author)Austringer2008-03-29
Duh, that's what Nintendo DS is for. Just kidding! But seriously, Instructables.com is for wasting time when time ought be wasted.
SFHandyman (author)RFilyaw2009-07-13
Someone criticized my "How to Make Butter" video on YouTube as a waste of time. (I uploaded it to illustrate my How to Make Butter Instructable)
Commenter #1: "Ever heard of Land O lakes? Too much work for so little yield. Does it taste that much "fresher" than just getting butter from the store?"
Commenter #2 "that's what i was thinkin :). would be good if you're retired i guess and really bored "
My reply "I find it funny that you thought it was a waste of time when you just watched a ten minute video on how to make butter --- but you don't want to make butter. hahaha / jk"
Commenter 2: "you may have a point there :) ".
HOMEPIE64 (author)InspectorD2007-06-25
as I said to someone else you are on a fricken website that is only diy where you spend fricken time doing projects and learning how are you saying that being a member of instructables(im not looking for confrentation im looking at a point of the matter)
gallowraven (author)2015-02-10
I find the coils can be made more quickly and easily with the use of a drill. I cut my mandrels to about 18 inches or so, and lock them into the chuck of the drill. I recommend wearing a leather work glove to protect the hand guiding the wire, as this method creates a lot of friction. I would say it is useful if you dont want to have to stop and make rings frequently after you begin weaving. I still cut them by hand though. I included a close up of my set up.
Jordans114 (author)2013-04-02
Hi! I am really interested in making some of this stuff, but I am having a hard time finding wire. I'm looking for Stainless Steel wire with a dimension of 16g SWG = 14g AWG = 0.063'' = 1.6mm. I live in Ontario, Canada, in the Waterloo region, if that helps anyone
JohnV1 (author)Jordans1142014-09-30
A popular wire to use is 14 gauge galvanized steel electric fence wire, you can get a quarter mile for under U.S.$50 at most hardware stores
Gaark (author)Jordans1142013-06-24
I'm jealous Jordans! I'd be living in this place if I was in Canada as well:
http://www.theringlord.com/
JohnV1 (author)2014-09-30
When adding the second row, and any rows thereafter, I found it is much faster and simpler to add one open ring with one closed ring and then work your way down the line one ring at a time, instead of adding a closed ring with two closed rings every other ring and then filling in the gaps. Hope this helps.
tonsfun43s (author)2014-02-02
sry, random question. what poster is that behind you lol.
Gorlakkur (author)2013-05-15
Great instructable, and great taste in music too! :-)
bamajax (author)2009-11-22
Ahh, yet another fellow Night Audit.  Welcome to the group!
repguy2020 (author)bamajax2013-05-12
Yes, the sleep-deprived, waaayyyy-too-much-time-on-our-hands group. =)
1010tbone (author)2009-10-20
Do people not get that "DIY" means just that?  Of course you can buy this stuff, but what happens when you can't?  Learning crafts such as these insures the survival of the knowlege.  I read a comment/question about butter and why would you spend so much time making it instead of buying it.  Well again "DIY" means just that and by learning how you become more independent. Give a man a fish...he eats for a day..but teach a man to fish and he eats for life....THAT IS WHY WE LEARN DIY!
icy45 (author)1010tbone2010-01-03
I always heard, give a man fire and he will be warm for a day, lite a man on fire and he will be warm the rest of his life.  Anyway great instructable but, how do you do curves easily?
kleinz (author)icy452010-03-25
 i think u mean, give a man fire and hell be warm for a day, but show him how to light a fire an he will be warm for the rest of his life.
repguy2020 (author)kleinz2013-05-12
Works both ways, but in one the life is a lot shorter!
wenpherd (author)kleinz2010-03-25
OR, give a man a fish and you'll feed him for a day, teach a man to fish and you'll feed him for a life time.
icy45 (author)wenpherd2010-03-25
If you're on fire, you'll be warm at least till you die.  I mean how do you get rid of people asking for free fish or fire, unless you use ninja fish against them...note we must research teaching fish to be ninjas.  Great idea teaching fish to be ninjas, I wish I thought of that.
wenpherd (author)icy452010-03-26
Yeah, Ninja Fish.
its not kung fu, its kung fish
fastfilmsinc (author)wenpherd2010-06-21
I always thought it was "Give a man a fish and he will eat for a day, teach a man to fish and he'll sit in a boat drinking beer all day".
wenpherd (author)fastfilmsinc2010-06-21
Heh.
Gunnar120 (author)wenpherd2010-07-07
I think you ALL mean........ "...Give a man a fish... they say... and he'll stink up a whole town.... Give a man a fishin' rod... Ya see where I'm going here? Yeah, Give him a fishin' rod and he'll poke your eye out..." Overheard from a drunkard of Albion
Doc Holliday (author)icy452010-08-02
I like that, it's correct, albeit his life will be quite short and he'll suffer inflammation.
DehLeprechaun (author)2011-11-12
Good Gravy!! If it took you 50 HOURS to do that coif then my plan for full body coverage of mail will NEVER happen, that's out the window...
sconner1 (author)DehLeprechaun2013-02-26
There's great pleasure to be taken from the satisfaction that you invested the time it takes to finish a long project. One can take a bag of rings along for all those wasted time of our lives like waiting or riding public transit where some might bring a book or knitting. Just make strips to assemble later as opposed to the whole project.
50 hours of speedweaving sounds funny xD
I'mma give it a shot and include some of my friends in making it. It's very cheap for what you get out of it :)
that aint nothing!!! i spent 50 hours making a 2" bracelet out of 24GA stearling silver rings. the bracelet was made for my son before he was born, and when he was born, it fit PERFECTLY.
yup, still not gonna happen!!!
a coif is a bit more complicated than a full ody maille suit tho. i made half a hauberk vest that went to my waist in about 3 or so hours...not counting the prep time (i made my own rings for that).
bored0ne (author)2012-10-30
How do you form it into shirts,hats,etc? Is there a template or something?
tinker234 (author)2011-08-14
wow how small can i make the chain mail also could i use titam andd other materials to absorb shock to make a retlvy bullet proof material
About This Instructable
327,474views
898favorites
License:
More by Paul the Mole:European 4-in-1 maille (chainmail) speedweaving
Add instructable to:
