Maille is a form of armour. It was invented by the Celts and it became very popular in the middle ages, where it was used as 'standard' armour for allmost all soldiers, because it's flexible and prevents cuts from swords, knives etc. Nowadays maille is made for other re-enactments, as 'alternative' clothing, or just for fun like I do.
Back in the days maille was made out of mild steel rings which were riveted. Which means: a lot of work. Today most of the maille is made out of steel wire. And it's not riveted anymore. It's called "butted".
The most common weave is without a doubt "European 4-in-1" (or E 4-1). This is the way the rings were linked in Europe in the middle ages. I'll come back later on the 4-in-1 thing.
I'm Belgian and I live in Brugge (Bruges). But when I was a child, I visited the "Gravensteen" (that's a castle castle) in Gent. There, someone was making maille at the time. I found it very fascinating and the thought of making some my own never leaved my mind really. Some time ago I started making my own maille. Currently I'm making a coif (have a look on Google Images if you don't know what a coif is).
The technique I use is called "speedweaving" because it's one of the fastest ways to make maille. What I will describe is not the only way to speedweave, but this is the one I use, and which works great for me. I did not invent this technique. I'm just sharing it with the world...
Remove these ads by
Signing UpStep 1Making the rings
I used galvanised steel wire. For two reasons: it's easily obtainable and it's cheap. My wire is 1,5 mm thick.
Making rings starts with transforming your wire into coils. And than cutting the coils with a mini bolt-cutter. I won't describe the whole coil-making process but I'll include some pictures of the way I do it. Perhaps I will come back to writing this piece out one day.
My coils have an inner diameter (ID) of 6 mm, but because of a thing called "springback" the rings have a real inner diameter (RID) of 6,4 mm). My rings have an aspect ratio (AR) of 4,3. This is the ratio of RID and the wire size.
I also like the explained method- not bad!
Commenter #1: "Ever heard of Land O lakes? Too much work for so little yield. Does it taste that much "fresher" than just getting butter from the store?"
Commenter #2 "that's what i was thinkin :). would be good if you're retired i guess and really bored "
My reply "I find it funny that you thought it was a waste of time when you just watched a ten minute video on how to make butter --- but you don't want to make butter. hahaha / jk"
Commenter 2: "you may have a point there :) ".
Thanks!
2. Yes, titanium can be used to make maille. Titanium wire, as well as other hard to find maille supplys can be purchased at theringlord.com.
3. Maille is not, and will not be bullet proof. Period. It was designed to deflect blades, and is not much good at anything else. If you are hit by a bullet while wearing maille, the bullet will most likely shatter the wire and drive it into your body; that would hurt.
