3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Even Simpler Flood and Drain System - The Mosquito
Due to the response of the last hydroponics system Flood and Drain from Junk, I figured I'd get this down while it's hot in my head because it answers some of the questions. Please do refer to the link above as it explains much of the theory.
I've simplified the system further to lend itself to massive expansion. The planter bottle has been modified to eliminate the need for interconnecting hoses as well as make it accept ANY airtight, and I recommend RIGID, reservoir. It sort of reminds me of a mosquito and works much the same way. As the air pump increases the pressure inside the reservoir, the nutrient sol'n is forced into the body of the mosquito. When the air pump is off, the resulting lower pressure allows gravity to return the nutrient to the reservoir and empty the body of the mosquito.
Modify as required and desired. For simplicity, I've quickly built a two planter unit out of stuff I had on hand and have ignored any efficiency issues. This is more to show the concept and although it "works", this one will not be used as a unit itself. I have also not filled the planters with bags of grow medium and plants for this same reason.
It'll be real short, I promise.
Step 1What You Need
What You Need
One airtight reservoir
One air pump
1/4 inch air tubing as required
Two pop bottles
Two 12 inch pieces of 1/2 inch CPVC pipe with one end cut at an angle
1 ea 5/8 inch drill bit
1 ea 7/32 inch drill bit
1 ea 9/16 inch drill bit (please pretend that's what's in the picture)
One drill (not shown)
45 comments
1-40 of 45next »
Oct 25, 2010. 2:48 AMspinningwoman says:
Can you explain how you made the second rigid tank? It looks like drainpipe. Really good instructible, thanks. I hadn't grasped why anyone would go for airpumping rather than water pump before reading this, but of course it means you can feed many chambers off one pipe/ pump.
Feb 18, 2010. 6:14 AMrnearhoof says:
Interesting, but I would still use a water pump. Of course a water pump can fail, but the airtight seal (which the system relies on) would be much, much more prone to failure than even the cheapest aquarium water pump.
Sep 26, 2008. 8:21 PMTheWelfareWarrior says:
interesting, interesting... What about if it goes too far and starts spilling, I don't want to babysit it for 5 minutes... If I was going to babysit it, couldn't I go even greener and use a footpump for an air matress?
Feb 7, 2009. 7:08 AMWafflicious says:
get one of those giant soda bottles
Jan 27, 2009. 12:28 AMaaronjehall says:
how bout one of those blowoff valves, like on a portable air tank? do they make them in that low of a pressure?
Jan 28, 2009. 1:53 AMaaronjehall says:
me neither. The bigger the diameter, however, the less of an issue clogging would be. ...however there are seizing issues the lower the pressure gets. How bout a crude cork gun approach? Use a champagne cork(mushroom shape)to stop up the hole on top. Put a stopper so the cork doesn't completely blow out.. I'd drill out the center halfway down and add fishing weights accordingly. Bake the cork to dry it, then soak in glycerine or Kroil to lube. I'm poor, so I always approach economically. Or maybe I'm completely out of my mind... Just glad to contribute.
Jan 30, 2009. 1:25 AMaaronjehall says:
i'm going to prob make this my first instructable, assuming i can find a more general version for multiple uses. i just have to think about what else it can be used for. if u wanna try it and post it, more power to you. if u can think of other general uses, plz help. Keep building!
Jan 11, 2009. 3:52 PMcynvision says:
This design has me thinking. I dislike getting the litter in the buckets because they're that plastic type "5" and my recycling center does not take it. But the bucket is a better "deal" price wise. This gives me something to build with them if I can scrounge up an air pump.
Jan 11, 2009. 11:21 PMcynvision says:
I'm curious if anyone has tried heating the plastic containers. With the Keep The Bottle contest going on I was inspired to try some PET sculpted bowls and the plastic becomes smaller but more stiff. I'm unsure what type 5 will do if I hit it with a heat gun.
Dec 10, 2008. 9:04 PMgreendreamer1537 says:
Thank you for this instructable - I have been wanting to make a hydroponic windowsill garden for a few months, and was looking at the expensive kits before I came across this. Your design is much more elegant (especially air pumps vs. water pumps), and I like re-using normally discarded materials. I'm going to build one in the next few weeks, I think using a 5 gallon bucket. I'll likely use c-clamps to keep the lid secure with the air pressure, and can fashion a gasket for the seal if it comes to that. I'm curious, though, about Step 4, where you say "seal any leaks as req'd". What have you found to be the best way to seal the leaks, and where are the problem areas? I'm curious if hot glue will work, or (more preferably) if rubber gaskets can be obtained in the correct size. Do you have any concerns about chemicals from hot glue / sealant leaking into your nutrient water and depositing in your plants? Again, thank you for the great instructables!
Nov 4, 2008. 1:30 PMlogic bomb says:
could you please take a pic of where to drill the holes in the air hose so the rest of us can understand what it is that you are talking about...step 3
Oct 22, 2008. 7:32 PMgrundisimo says:
Oct 29, 2008. 4:57 PMgrundisimo says:
I don't know what this is supposed to do or be.
Nov 1, 2008. 6:35 AMgrundisimo says:
I'm sorry that i didn't reply yesterday I just barely found your comment because Annoying Brother #1 barely let me have the computer because he is still asleep.
Oct 31, 2008. 8:11 AMtabletopphoto says:
what size air pump are you using?
Nov 1, 2008. 6:59 AMtabletopphoto says:
why not make use of both outlets and double your air pressure by joining together as one tube? The benefit would be more oxygen to the roots right?
Oct 31, 2008. 8:54 AMtabletopphoto says:
I wonder how well this system will work for aquaponics
Oct 11, 2008. 3:57 AMSpecEd says:
I have heard of hydroponics, but never read up on it. Your plans are inspiring me to do so! BTW, the mosquito is a much cleaner and hence, less daunting proposal... VERY COOL! What exactly is the "nutrient", is this simply liquid fertilizer, e.g., MiracleGro? That looks to be a pretty significant (e.g., bigger than a garden variety aquarium) pump. If I do this, I will be using a similar (i.e., different in brand of kitty litter) reservoir; could you spec the pump you used please?
Oct 13, 2008. 12:10 PMSpecEd says:
Thanks for the reply! I'll consider the comments on kitty litter container, but don't think I can resist the urge to try to to use it (I was thinking of caulking/melting shut the large side of the hinged top, for more strength. The pump name/model is much appreciated!
Oct 1, 2008. 10:34 PMm_yazhini says:
it is nice
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:wiley coyote
